Review on solving the inverse problem in EEG source analysis, Journal of NeuroEngineering and Rehabilitation, vol.5, issue.1, p.25, 2008. ,
DOI : 10.1186/1743-0003-5-25
Multiresolution imaging of MEG cortical sources using an explicit piecewise model, NeuroImage, vol.38, issue.3, pp.439-451, 2007. ,
DOI : 10.1016/j.neuroimage.2007.07.046
MEG Source Localization of Spatially Extended Generators of Epileptic Activity: Comparing Entropic and Hierarchical Bayesian Approaches, PLoS ONE, vol.2011, issue.2, p.55969, 2013. ,
DOI : 10.1371/journal.pone.0055969.s004
Connectivity-Based Parcellation of Broca's Area, Cerebral Cortex, vol.17, issue.4, pp.816-825, 2007. ,
DOI : 10.1093/cercor/bhk034
Biomagnetic Source Detection by Maximum Entropy and Graphical Models, IEEE Transactions on Biomedical Engineering, vol.51, issue.3, pp.427-442, 2004. ,
DOI : 10.1109/TBME.2003.820999
Multiple sparse priors for the M/EEG inverse problem, NeuroImage, vol.39, issue.3, pp.1104-1120, 2008. ,
DOI : 10.1016/j.neuroimage.2007.09.048
Multivariate source prelocalization (MSP): Use of functionally informed basis functions for better conditioning the MEG inverse problem, NeuroImage, vol.26, issue.2, pp.356-373, 2005. ,
DOI : 10.1016/j.neuroimage.2005.01.026
A Parametric Empirical Bayesian Framework for the EEG/MEG Inverse Problem: Generative Models for Multi-Subject and Multi-Modal Integration, Frontiers in Human Neuroscience, vol.5, issue.76, 2011. ,
DOI : 10.3389/fnhum.2011.00076
A multi-subject, multi-modal human neuroimaging dataset, Scientific Data, 2015. ,
DOI : 10.1088/0031-9155/48/22/002
Cortical Surface-Based Analysis, NeuroImage, vol.9, issue.2, p.179194, 1999. ,
DOI : 10.1006/nimg.1998.0395
Brainstorm: A User-Friendly Application for MEG/EEG Analysis, Computational Intelligence and Neuroscience, vol.57, issue.1, p.19, 2011. ,
DOI : 10.1002/hbm.20781
Advances in functional and structural MR image analysis and implementation as FSL, Mathematics in Brain Imag- ing, pp.208-219, 2004. ,
DOI : 10.1016/j.neuroimage.2004.07.051
OpenMEEG: opensource software for quasistatic bioelectromagnetics, BioMedical Engineering OnLine, vol.9, issue.1, p.45, 2010. ,
DOI : 10.1186/1475-925X-9-45
URL : https://hal.archives-ouvertes.fr/inria-00467061
MEG and EEG data analysis with MNE-Python, Frontiers in Neuroscience, vol.7, issue.267, 2013. ,
DOI : 10.3389/fnins.2013.00267
Probabilistic diffusion tractography with multiple fibre orientations: What can we gain?, NeuroImage, vol.34, issue.1, pp.144-155, 2007. ,
DOI : 10.1016/j.neuroimage.2006.09.018
A network of occipito-temporal face-sensitive areas besides the right middle fusiform gyrus is necessary for normal face processing, Brain, vol.126, issue.11, pp.2381-2395, 2003. ,
DOI : 10.1093/brain/awg241
Recognition memory of newly learned faces, Brain Research Bulletin, vol.71, issue.1-3, pp.167-173, 2006. ,
DOI : 10.1016/j.brainresbull.2006.08.017
The Effect of Face Inversion on Activity in Human Neural Systems for Face and Object Perception, Neuron, vol.22, issue.1, pp.189-199, 1999. ,
DOI : 10.1016/S0896-6273(00)80690-X
Attention inhibition of early cortical activation to fearful faces, Brain Research, vol.1313, issue.0, pp.113-123, 2010. ,
DOI : 10.1016/j.brainres.2009.11.060
