Measuring the Objectness of Image Windows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.34, issue.11, 2012. ,
DOI : 10.1109/TPAMI.2012.28
Robust Object Tracking with Online Multiple Instance Learning, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.8, 2011. ,
DOI : 10.1109/TPAMI.2010.226
Probabilistic Color and Adaptive Multi-Feature Tracking with Dynamically Switched Priority Between Cues, 2007 IEEE 11th International Conference on Computer Vision, 2007. ,
DOI : 10.1109/ICCV.2007.4408955
Elliptical head tracking using intensity gradients and color histograms, Proceedings. 1998 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No.98CB36231), 1998. ,
DOI : 10.1109/CVPR.1998.698614
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.49.5898
Large Displacement Optical Flow: Descriptor Matching in Variational Motion Estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.3, pp.510-513, 2011. ,
DOI : 10.1109/TPAMI.2010.143
Constrained parametric min-cuts for automatic object segmentation, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2010. ,
DOI : 10.1109/CVPR.2010.5540063
Online selection of discriminative tracking features, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.10, 2005. ,
DOI : 10.1109/TPAMI.2005.205
Kernel-based object tracking, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.5, pp.564-577, 2003. ,
DOI : 10.1109/TPAMI.2003.1195991
Histograms of Oriented Gradients for Human Detection, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), 2005. ,
DOI : 10.1109/CVPR.2005.177
URL : https://hal.archives-ouvertes.fr/inria-00548512
Accurate Scale Estimation for Robust Visual Tracking, Proceedings of the British Machine Vision Conference 2014, 2014. ,
DOI : 10.5244/C.28.65
Structured Forests for Fast Edge Detection, 2013 IEEE International Conference on Computer Vision, 2013. ,
DOI : 10.1109/ICCV.2013.231
LIBLINEAR: A library for large linear classification, pp.1871-1874, 2008. ,
Object Detection with Discriminatively Trained Part-Based Models, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.9, pp.1627-1645, 2010. ,
DOI : 10.1109/TPAMI.2009.167
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.2745
Hough-based tracking of non-rigid objects, ICCV, 2011. ,
Semi-supervised On-Line Boosting for Robust Tracking, ECCV, 2008. ,
DOI : 10.1007/978-3-540-88682-2_19
Struck: Structured output tracking with kernels, ICCV, 2011. ,
Multiple View Geometry in Computer Vision, 2004. ,
DOI : 10.1017/CBO9780511811685
Method and means for recognizing complex patterns, US Patent, vol.3, p.69654, 1962. ,
Occlusion and Motion Reasoning for Long-Term Tracking, ECCV, 2014. ,
DOI : 10.1007/978-3-319-10599-4_12
URL : https://hal.archives-ouvertes.fr/hal-01020149
Icondensation: Unifying low-level and high-level tracking in a stochastic framework, ECCV, 1998. ,
DOI : 10.1007/BFb0055711
Visual tracking via adaptive structural local sparse appearance model, CVPR, 2012. ,
Tracking-learningdetection, pp.1409-1422, 2012. ,
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, 1960. ,
DOI : 10.1115/1.3662552
A Novel Performance Evaluation Methodology for Single-Target Trackers, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.38, issue.11, 2015. ,
DOI : 10.1109/TPAMI.2016.2516982
Tracking by sampling trackers, ICCV, 2011. ,
Visual tracking and recognition using probabilistic appearance manifolds, Computer Vision and Image Understanding, vol.99, issue.3, pp.303-331, 2005. ,
DOI : 10.1016/j.cviu.2005.02.002
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.65.5240
Coupled Object Detection and Tracking from Static Cameras and Moving Vehicles, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.10, pp.1683-1698, 2008. ,
DOI : 10.1109/TPAMI.2008.170
Distinctive Image Features from Scale-Invariant Keypoints, International Journal of Computer Vision, vol.60, issue.2, pp.91-110, 2004. ,
DOI : 10.1023/B:VISI.0000029664.99615.94
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.4931
The Visual Object Tracking VOT2014 Challenge Results, ECCV Visual Object Tracking Challenge Workshop, 2014. ,
DOI : 10.1007/978-3-319-16181-5_14
URL : https://hal.archives-ouvertes.fr/hal-01301090
The template update problem, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.6, pp.810-815, 2004. ,
DOI : 10.1109/TPAMI.2004.16
Robust visual tracking and vehicle classification via sparse representation, 2011. ,
Consensus-based matching and tracking of keypoints for object tracking, IEEE Winter Conference on Applications of Computer Vision, 2014. ,
DOI : 10.1109/WACV.2014.6836013
Finding the Best from the Second Bests - Inhibiting Subjective Bias in Evaluation of Visual Tracking Algorithms, 2013 IEEE International Conference on Computer Vision, 2013. ,
DOI : 10.1109/ICCV.2013.346
Robust visual tracking using autoregressive hidden Markov model, CVPR, 2012. ,
Data Fusion for Visual Tracking With Particles, Proc. IEEE, pp.495-513, 2004. ,
DOI : 10.1109/JPROC.2003.823147
Probabilistic outputs for support vector machines and comparisons to regularized likelihood methods, NIPS, 1999. ,
Tracking People by Learning Their Appearance, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.1, pp.65-81, 2007. ,
DOI : 10.1109/TPAMI.2007.250600
Visual tracking: An experimental survey, PAMI, vol.36, issue.7, pp.1442-1468, 2014. ,
Tracking Revisited Using RGBD Camera: Unified Benchmark and Baselines, 2013 IEEE International Conference on Computer Vision, 2013. ,
DOI : 10.1109/ICCV.2013.36
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.300.921
Towards robust multi-cue integration for visual tracking. Machine Vis, 2003. ,
Learning to track with multiple observers, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206634
Self-Paced Learning for Long-Term Tracking, 2013 IEEE Conference on Computer Vision and Pattern Recognition, 2013. ,
DOI : 10.1109/CVPR.2013.308
Learning to detect Motion Boundaries, 2015 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2015. ,
DOI : 10.1109/CVPR.2015.7298873
URL : https://hal.archives-ouvertes.fr/hal-01142653
Detection and tracking of multiple , partially occluded humans by Bayesian combination of edgelet based part detectors. IJCV, 2007. ,
Online Object Tracking: A Benchmark, 2013 IEEE Conference on Computer Vision and Pattern Recognition, 2013. ,
DOI : 10.1109/CVPR.2013.312
MEEM: Robust Tracking via Multiple Experts Using Entropy Minimization, ECCV, 2014. ,
DOI : 10.1007/978-3-319-10599-4_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.666.3510
Robust object tracking via sparsity-based collaborative model, 2012 IEEE Conference on Computer Vision and Pattern Recognition, 2012. ,
DOI : 10.1109/CVPR.2012.6247882
Edge Boxes: Locating Object Proposals from Edges, ECCV, 2014. ,
DOI : 10.1007/978-3-319-10602-1_26
