SIF Permutations and Chord-Connected Permutations
A stabilized-interval-free (SIF) permutation on [n], introduced by Callan, is a permutation that does not stabilize any proper interval of [n]. Such permutations are known to be the irreducibles in the decomposition of permutations along non-crossing partitions. That is, if $s_n$ denotes the number of SIF permutations on [n], $S(z)=1+\sum_{n\geq1} s_n z^n$, and $F(z)=1+\sum_{n\geq1} n! z^n$, then $F(z)= S(zF(z))$. This article presents, in turn, a decomposition of SIF permutations along non-crossing partitions. Specifically, by working with a convenient diagrammatic representation, given in terms of perfect matchings on alternating binary strings, we arrive at the \emphchord-connected permutations on [n], counted by $\{c_n\}_{n\geq1}$, whose generating function satisfies $S(z)= C(zS(z))$. The expressions at hand have immediate probabilistic interpretations, via the celebrated moment-cumulant formula of Speicher, in the context of the free probability theory of Voiculescu. The probability distributions that appear are the exponential and the complex Gaussian.
