New interface
Reports (Research report)
Object Classification via Planar Abstraction
Sven Oesau 1 Florent Lafarge 1 Pierre Alliez 1
1 TITANE - Geometric Modeling of 3D Environments
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We present a supervised machine learning approach for classification of objects from sampled point data. The main idea consists in first abstracting the input object into planar parts at several scales, then discriminate between the different classes of objects solely through features derived from these planar shapes. Abstracting into planar shapes provides a means to both reduce the computational complexity and improve robustness to defects inherent to the acquisition process. Measuring statistical properties and relationships between planar shapes offers invariance to scale and orientation. A random forest is then used for solving the multiclass classification problem. We demonstrate the potential of our approach on a set of indoor objects from the Princeton shape benchmark and on objects acquired from indoor scenes and compare the performance of our method with other point-based shape descriptors.
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01207676
Contributor : Sven Oesau Connect in order to contact the contributor
Submitted on : Friday, October 16, 2015 - 11:11:06 AM
Last modification on : Wednesday, October 26, 2022 - 8:15:05 AM
Long-term archiving on: : Monday, January 18, 2016 - 6:01:03 AM
File
RR-8782.pdf
Identifiers
  • HAL Id : hal-01207676, version 2
Collections
Citation
Sven Oesau, Florent Lafarge, Pierre Alliez. Object Classification via Planar Abstraction. [Research Report] RR-8782, INRIA Sophia Antipolis - Méditerranée. 2015, pp.14. ⟨hal-01207676v2⟩
Share
Metrics
Record views
358
Files downloads
279
