New interface
Conference papers
Sketching for Large-Scale Learning of Mixture Models
Nicolas Keriven 1 Anthony Bourrier 1, 2 Rémi Gribonval 1 Patrick Pérez 2
1 PANAMA - Parcimonie et Nouveaux Algorithmes pour le Signal et la Modélisation Audio
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Learning parameters from voluminous data can be prohibitive in terms of memory and computational requirements. We propose a "compressive learning'' framework where we first sketch the data by computing random generalized moments of the underlying probability distribution, then estimate mixture model parameters from the sketch using an iterative algorithm analogous to greedy sparse signal recovery. We exemplify our framework with the sketched estimation of Gaussian Mixture Models (GMMs). We experimentally show that our approach yields results comparable to the classical Expectation-Maximization (EM) technique while requiring significantly less memory and fewer computations when the number of database elements is large. We report large-scale experiments in speaker verification, where our approach makes it possible to fully exploit a corpus of 1000 hours of speech signal to learn a universal background model at scales computationally inaccessible to EM.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01208027
Contributor : Nicolas Keriven Connect in order to contact the contributor
Submitted on : Tuesday, March 1, 2016 - 11:49:44 AM
Last modification on : Friday, January 21, 2022 - 3:22:54 AM
Long-term archiving on: : Tuesday, May 31, 2016 - 11:19:36 AM
File
paper.pdf
Identifiers
  • HAL Id : hal-01208027, version 3
Relations
  • references hal-02960718 - software for reproducible research
Citation
Nicolas Keriven, Anthony Bourrier, Rémi Gribonval, Patrick Pérez. Sketching for Large-Scale Learning of Mixture Models. 2016 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP 2016), Mar 2016, Shanghai, China. ⟨hal-01208027v3⟩
Share
Metrics
Record views
893
Files downloads
863
