The amplitude equation for weakly nonlinear reversible phase boundaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
This technical note is a complement to an earlier paper [Benzoni-Gavage & Rosini, Comput. Math. Appl. 2009], which aims at a deeper understanding of a basic model for propagating phase boundaries that was proved to admit surface waves [Benzoni-Gavage, Nonlinear Anal. 1998]. The amplitude equation governing the evolution of weakly nonlinear surface waves for that model is computed explicitly, and is eventually found to have enough symmetry properties for the associated Cauchy problem to be locally well-posed.
Note_HAL.pdf (277.01 Ko) Télécharger le fichier
hal-01208192 , version 1 (02-10-2015)
Sylvie Benzoni-Gavage, Jean-François Coulombel. The amplitude equation for weakly nonlinear reversible phase boundaries. [Research Report] CNRS. 2015. ⟨hal-01208192⟩
351 Consultations
103 Téléchargements
