Using IEEE 802.15.4e Time-Slotted Channel Hopping (TSCH) in the Internet of Things (IoT): Problem Statement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Internet Engineering Task Force Année : 2015
This document describes the environment, problem statement, and goals for using the Time-Slotted Channel Hopping (TSCH) Medium Access Control (MAC) protocol of IEEE 802.14.4e in the context of Low-Power and Lossy Networks (LLNs). The set of goals enumerated in this document form an initial set only.
Fichier non déposé
hal-01208395 , version 1 (02-10-2015)
  • HAL Id : hal-01208395 , version 1
Thomas Watteyne, Maria-Rita Palattella, Luigi Alfredo Grieco. Using IEEE 802.15.4e Time-Slotted Channel Hopping (TSCH) in the Internet of Things (IoT): Problem Statement. Internet Engineering Task Force, 2015. ⟨hal-01208395⟩
Collections
INRIA INRIA2
1107 Consultations
0 Téléchargements
