A Short Isabelle/HOL Tutorial for the Functional Programmer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
Thomas Genet
The objective of this (very) short tutorial is to help any functional programmer to quickly put its hand on Isabelle/HOL and catch a glimpse of its power. Then, if you want some more, you should refer to the extensive Isabelle/HOL tutorial and documentation available in the tool.
main.pdf (165.6 Ko) Télécharger le fichier
hal-01208577 , version 1 (02-10-2015)
hal-01208577 , version 2 (15-10-2015)
hal-01208577 , version 3 (06-11-2015)
hal-01208577 , version 4 (15-06-2016)
hal-01208577 , version 5 (15-05-2017)
hal-01208577 , version 6 (28-08-2018)
hal-01208577 , version 7 (26-08-2020)
hal-01208577 , version 8 (20-09-2021)
hal-01208577 , version 9 (04-01-2023)
  • HAL Id : hal-01208577 , version 1
Thomas Genet. A Short Isabelle/HOL Tutorial for the Functional Programmer. [Research Report] IRISA. 2015. ⟨hal-01208577v1⟩
984 Consultations
6327 Téléchargements
