A Short Isabelle/HOL Tutorial for the Functional Programmer
The objective of this (very) short tutorial is to help any functional programmer to quickly put its hand on Isabelle/HOL and catch a glimpse of its power. Then, if you want some more, you should refer to the extensive Isabelle/HOL tutorial and documentation available in the tool.
