Asymptotic Stabilization of Linear Time-Varying Systems with Input Delays via Delayed Static Output Feedback
A family of linear time-varying systems with an input, an output and delays in the input is considered. It is shownthat, under a stabilizability and a detectability assumption, systems of this family can be exponentially stabilized through atime-varying feedback depending on past values of the output and the input.
