Semi-intelligible Isar Proofs from Machine-Generated Proofs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2016
Sledgehammer is a component of the Isabelle/HOL proof assistant that integrates external automatic theorem provers (ATPs) to discharge interactive proof obligations. As a safeguard against bugs, the proofs found by the external provers are reconstructed in Isa-belle. Reconstructing complex arguments involves translating them to Isabelle's Isar format, supplying suitable justifications for each step. Sledgehammer transforms the proofs by contradiction into direct proofs; it iteratively tests and compresses the output, resulting in simpler and faster proofs; and it supports a wide range of ATPs, including E, LEO-II, Satallax, SPASS, Vampire, veriT, Waldmeister, and Z3.
paper.pdf (459.25 Ko) Télécharger le fichier
hal-01211748 , version 1 (05-10-2015)
Jasmin Christian Blanchette, Sascha Böhme, Mathias Fleury, Steffen Juilf Smolka, Albert Steckermeier. Semi-intelligible Isar Proofs from Machine-Generated Proofs. Journal of Automated Reasoning, 2016, ⟨10.1007/s10817-015-9335-3⟩. ⟨hal-01211748⟩
273 Consultations
322 Téléchargements
