Abstract : This document presents an interpolation operator on unstructured tetrahedral meshes that satisfies the properties
of mass conservation, P1-exactness (order 2) and maximum principle.
Interpolation operators are important for many applications in scientific computing.
For instance, in the context of anisotropic mesh adaptation for time-dependent problems, the interpolation stage
becomes crucial as the error due to solution transfer accumulates throughout the simulation.
This error can eventually spoil the overall solution accuracy.
When dealing with conservation laws in CFD, solution accuracy requires enforcement of mass preservation throughout the computation,
in particular in long time scale computations.
In the proposed approach, the conservation property is achieved by local mesh intersection and quadrature formulae.
Derivatives reconstruction is used to obtain a second order method. Algorithmically, our goal is to design a method
which is robust and efficient. The robustness is mandatory to obtain a reliable method on real-life applications and
to apply the operator to highly anisotropic meshes.
The efficiency is achieved by designing a matrix-free operator which is highly parallel.
A multi-thread parallelization is given in this work.
Several numerical examples are presented to illustrate the efficiency of the proposed approach.
