Multi-threaded Active Objects ,
DOI : 10.1007/978-3-642-38493-6_7
URL : https://hal.archives-ouvertes.fr/hal-01486037
Abs: A core language for abstract behavioral specification. Formal Methods for Components and Objects, 2012. ,
Asynchronous and deterministic objects, Proceedings of the 31st ACM SIGPLAN-SIGACT symposium on Principles of programming languages, pp.123-134, 2004. ,
Asynchronous sequential processes, Information and Computation, vol.207, issue.4, pp.459-495, 2009. ,
DOI : 10.1016/j.ic.2008.12.004
URL : https://hal.archives-ouvertes.fr/inria-00071834
Creol: A type-safe object-oriented model for distributed concurrent systems, Theoretical Computer Science, vol.365, issue.1-2, pp.23-66, 2006. ,
DOI : 10.1016/j.tcs.2006.07.031
JCoBox: Generalizing Active Objects to Concurrent Components, ECOOP 2010?Object-Oriented Programming, pp.275-299, 2010. ,
DOI : 10.1007/978-3-642-14107-2_13
Active Object ? An Object Behavioral Pattern for Concurrent Programming, 1996. ,
CoG kits, Proceedings of the ACM 2000 conference on Java Grande , JAVA '00, 2000. ,
DOI : 10.1145/337449.337491
The Cactus Code: a problem solving environment for the grid, Proceedings the Ninth International Symposium on High-Performance Distributed Computing, 2000. ,
DOI : 10.1109/HPDC.2000.868657
Ninf: Network-based information library for globally high performance computing, Paral lel Object-Oriented Methods and Applications (POOMA), pp.39-48, 1996. ,
Grid-Based Asynchronous Migration of Execution Context in Java Virtual Machines ,
DOI : 10.1007/3-540-44520-X_3
A grid programming primer, Draft 2.4 of the Programming Models Working Group presented at the Global Grid Forum 1, 2001. ,
