Robust Finite-time Stabilization and Observation of a Planar System Revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The second order planar nonlinear affine control problem is studied. A homogeneous robust finite-time stabilizing control is developed for the most general case of matched and, the more challenging, mismatched nonlinear perturbations. A homogeneous observer is designed for the planar system. Explicit restrictions on the observer gains and nonlinearities are presented. The main contribution lies in the proposed combination of the explicit and implicit Lyapunov function methods as well as weighted homogeneity while providing finite-time stability analysis. Theoretical results are supported by numerical simulations.
Automatique
CDC15_0106_FI.pdf (428.78 Ko) Télécharger le fichier
hal-01212582 , version 1 (06-10-2015)
  • HAL Id : hal-01212582 , version 1
Andrey Polyakov, Yuri Orlov, Harshal Oza, Sarah Spurgeon. Robust Finite-time Stabilization and Observation of a Planar System Revisited. 54th conference on Decision and Control 2015, IEEE, Dec 2015, Osaka, Japan. ⟨hal-01212582⟩
319 Consultations
240 Téléchargements
