Foundational Extensible Corecursion: A Proof Assistant Perspective - Archive ouverte HAL Access content directly
Conference Papers Year : 2015
This paper presents a formalized framework for defining corecursive functions safely in a total setting, based on corecursion up-to and relational parametricity. The end product is a general corecursor that allows corecursive (and even recursive) calls under "friendly" operations, including constructors. Friendly corecursive functions can be registered as such, thereby increasing the corecursor's expressiveness. The metatheory is formalized in the Isabelle proof assistant and forms the core of a prototype tool. The corecursor is derived from first principles, without requiring new axioms or extensions of the logic.
fouco.pdf (261.06 Ko) Télécharger le fichier
Dates and versions
hal-01212589 , version 1 (07-10-2015)
Identifiers
Cite
Jasmin Christian Blanchette, Andrei Popescu, Dmitriy Traytel. Foundational Extensible Corecursion: A Proof Assistant Perspective. ICFP 2015, Aug 2015, Vancouver, Canada. ⟨10.1145/2784731.2784732⟩. ⟨hal-01212589⟩
77 View
73 Download
Share
