Discontinuous automatic control, 1953. ,
DOI : 10.1515/9781400877218
URL : http://hdl.handle.net/2027/mdp.39015013755437
Relay Control Systems, Moscow: Nauka, 1984. ,
Discontinuous Control Systems: Frequency-Domain Analysis and Design, 2009. ,
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Principles of 2-sliding mode design, Automatica, vol.43, issue.4, pp.576-586, 2007. ,
DOI : 10.1016/j.automatica.2006.10.008
Unified Lyapunov function for a finite-time stability analysis of relay second-order sliding mode control systems, IMA Journal of Mathematical Control and Information, vol.29, issue.4, pp.529-550, 2012. ,
DOI : 10.1093/imamci/dns007
A survey of applications of second-order sliding mode control to mechanical systems, International Journal of Control, vol.76, issue.9-10, pp.875-892, 2003. ,
DOI : 10.1080/0020717031000099010
An introduction to hybrid dynamical systems, 2000. ,
DOI : 10.1007/BFb0109998
Stability Criteria for Switched and Hybrid Systems, SIAM Review, vol.49, issue.4, pp.545-592, 2007. ,
DOI : 10.1137/05063516X
Quadratic stabilization of a switched affine system about a nonequilibrium point, Proceeding of the, 2004. ,
Switched affine systems control design with application to DC???DC converters, IET Control Theory & Applications, vol.4, issue.7, pp.1201-1210, 2010. ,
DOI : 10.1049/iet-cta.2009.0246
On Practical Stability and Stabilization of Hybrid and Switched Systems, IEEE Transactions on Automatic Control, vol.50, issue.11, pp.1897-1903, 2005. ,
DOI : 10.1007/978-3-540-24743-2_41
Variable Structure Control With Generalized Relays: A Simple Convex Optimization Approach, IEEE Transactions on Automatic Control, vol.60, issue.2, pp.497-502, 2015. ,
DOI : 10.1109/TAC.2014.2331417
URL : https://hal.archives-ouvertes.fr/hal-01006389
A solution of the problem of synthesis using a controllability function, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Simplex sliding mode control of multi-input systems with chattering reduction and mono-directional actuators, Automatica, vol.47, issue.11, pp.2433-2437, 2011. ,
DOI : 10.1016/j.automatica.2011.08.011
Vector method of design of sliding motion and simplex algorithms, Automation and Remote Control, vol.46, pp.830-837, 1985. ,
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.42, issue.10, 2015. ,
DOI : 10.1002/rnc.3297
URL : https://hal.archives-ouvertes.fr/hal-01160052
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Block control principle I, Automation and Remote Control, vol.51, issue.5, pp.601-609, 1990. ,
Nonlinear Feedback Design for Fixed-Time Stabilization of Linear Control Systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
DOI : 10.1109/TAC.2011.2179869
URL : https://hal.archives-ouvertes.fr/hal-00757561
A new homogeneous quasi-continuous second order sliding mode control, Latinamerican Congress on Automatic Control, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01090716
Introduction to calculus and analysis (, 2000. ,
