Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
Recursive state estimation for a set-membership description of uncertainty. Automatic Control, IEEE Transactions on, vol.16, issue.2, pp.117-128, 1971. ,
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.760-770, 1986. ,
DOI : 10.1137/S0363012997321358
State estimation for dynamic systems, Boca Raton, 1994. ,
Introduction to Calculus and Analysis (Vol. I/II), 2000. ,
Output linear controller for a class of nonlinear systems using the invariant ellipsoid technique, 2009 American Control Conference, pp.1160-1165, 2009. ,
DOI : 10.1109/ACC.2009.5160434
Finite Time Controllers, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
DOI : 10.1137/0324047
Neural networks and learning machines, 2009. ,
A GENERAL APPROACH TO THE SOLUTION OF THE BOUNDED CONTROL SYNTHESIS PROBLEM IN A CONTROLLABILITY PROBLEM, Mathematics of the USSR-Sbornik, vol.37, issue.4, p.582606, 1979. ,
DOI : 10.1070/SM1980v037n04ABEH002094
Control and observation under uncertainty (in Russian), 1977. ,
The Stability of Dynamical Systems, 1976. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
DOI : 10.1016/j.automatica.2004.11.029
Robust control for a class of continuous-time dynamical systems with sample-data outputs, 2009 6th International Conference on Electrical Engineering, Computing Science and Automatic Control (CCE), pp.1-7, 2009. ,
DOI : 10.1109/ICEEE.2009.5393420
Finite time stability and stabilization of a class of continuous systems, Journal of Mathematical Analysis and Applications, vol.323, issue.2, pp.1430-1443, 2006. ,
DOI : 10.1016/j.jmaa.2005.11.046
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, p.12531271, 2005. ,
DOI : 10.1137/S0363012903425593
Advanced H ? Control, 2014. ,
DOI : 10.1007/978-1-4939-0292-7
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
Ellipsoidal parameter or state estimation under model uncertainty, Automatica, vol.40, issue.7, pp.1171-1179, 2004. ,
DOI : 10.1016/j.automatica.2004.02.014
Suppression of bounded exogenous disturbances: Output feedback. Automation and Remote Control, pp.801-818, 2008. ,
Finitetime stabilization using implicit Lyapunov function technique, 9th Symposium on Nonlinear Control Systems, pp.140-145, 2013. ,
DOI : 10.3182/20130904-3-fr-2041.00043
URL : https://hal.archives-ouvertes.fr/hal-00844386
Homogeneous differentiator design using implicit Lyapunov Function method, 2014 European Control Conference (ECC), pp.288-293, 2014. ,
DOI : 10.1109/ECC.2014.6862399
URL : https://hal.archives-ouvertes.fr/hal-01003992
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, p.332340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Practical output feedback stabilisation for a class of continuous-time dynamic systems under sample-data outputs, International Journal of Control, vol.36, issue.8, pp.1408-1416, 2011. ,
DOI : 10.1016/j.automatica.2008.07.013
Attractive Ellipsoids in Robust Control, 2014. ,
DOI : 10.1007/978-3-319-09210-2
URL : https://hal.archives-ouvertes.fr/hal-01088632
Recursive state estimation: Unknown but bounded errors and system inputs. Automatic Control, IEEE Transactions on, vol.13, issue.1, pp.22-28, 1968. ,
DOI : 10.1109/sap.1967.272985
Ellipsoidal Set-Theoretic Control Synthesis, Journal of Dynamic Systems, Measurement, and Control, vol.104, issue.4, pp.331-336, 1981. ,
DOI : 10.1115/1.3139718
Sliding Modes in Control and Optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Methods of A.M. Lyapunov and Their Applications. Noordhoff, 1964. ,
