A Short SPAN+AVISPA Tutorial - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
The objective of this short tutorial is to show how to use SPAN to understand and debug HLPSL specifications used in the AVISPA cryptographic protocol verification tool. The reader is supposed to be familiar with the HLPSL language, if not please read the HLPSL tutorial first.
main.pdf (875.47 Ko) Télécharger le fichier
hal-01213074 , version 1 (07-10-2015)
hal-01213074 , version 2 (15-10-2015)
hal-01213074 , version 3 (06-11-2015)
hal-01213074 , version 4 (04-05-2016)
hal-01213074 , version 5 (27-02-2017)
  • HAL Id : hal-01213074 , version 1
Thomas Genet. A Short SPAN+AVISPA Tutorial. [Research Report] IRISA. 2015. ⟨hal-01213074v1⟩
Relations
5700 Consultations
6013 Téléchargements
