Linearly Homomorphic Encryption from DDH - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We design a linearly homomorphic encryption scheme whose security relies on the hardness of the decisional Diffie-Hellman problem. Our approach requires some special features of the underlying group. In particular, its order is unknown and it contains a subgroup in which the discrete logarithm problem is tractable. Therefore, our instantiation holds in the class group of a non maximal order of an imaginary quadratic field. Its algebraic structure makes it possible to obtain such a linearly homomorphic scheme whose message space is the whole set of integers modulo a prime p and which supports an unbounded number of additions modulo p from the ciphertexts. A notable difference with previous works is that, for the first time, the security does not depend on the hardness of the factorization of integers. As a consequence, under some conditions, the prime p can be scaled to fit the application needs.
CTRSA15_ddhhomo_extended.pdf (450.57 Ko) Télécharger le fichier
hal-01213284 , version 1 (08-10-2015)
Guilhem Castagnos, Fabien Laguillaumie. Linearly Homomorphic Encryption from DDH. The Cryptographer's Track at the RSA Conference 2015, Apr 2015, San Francisco, United States. ⟨10.1007/978-3-319-16715-2_26⟩. ⟨hal-01213284⟩
305 Consultations
518 Téléchargements
