New interface
Conference papers
Featherweight OCL: A Proposal for a Machine-Checked Formal Semantics for OCL 2.5
Abstract : The Unified Modeling Language (UML) is one of the few modeling languages that is widely used in industry. While UML is mostly known as diagrammatic modeling language (e.g., visualizing class models), it is complemented by a textual language, called Object Constraint Language (OCL). OCL is a textual annotation language, originally based on a three-valued logic, that turns UML into a formal language. Unfortunately the semantics of this specification language, captured in the “Annex A” of the OCL standard, leads to different interpretations of corner cases. Many of these corner cases had been subject to formal analysis since more than ten years. The situation complicated with the arrival of version 2.3 of the OCL standard. OCL was aligned with the latest version of UML: this led to the extension of the three-valued logic by a second exception element, called null. While the first exception element invalid has a strict semantics, null has a non strict interpretation. The combination of these semantic features lead to remarkable confusion for implementors of OCL compilers and interpreters. In this paper, we provide a formalization of the core of OCL in HOL. It provides denotational definitions, a logical calculus and operational rules that allow for the execution of OCL expressions by a mixture of term rewriting and code compilation. Moreover, we describe a coding-scheme for UML class models that were annotated by code-invariants and code contracts. An implementation of this coding-scheme has been undertaken: it consists of a kind of compiler that takes a UML class model and translates it into a family of definitions and derived theorems over them capturing the properties of constructors and selectors, tests and casts resulting from the class model. However, this compiler is not included in this document. Our formalization reveals several inconsistencies and contradictions in the current version of the OCL standard. They reflect a challenge to define and implement OCL tools in a uniform manner. Overall, this document is intended to provide the basis for a machine-checked text “Annex A” of the OCL standard targeting at tool implementors.
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-01213440
Contributor : Burkhart Wolff Connect in order to contact the contributor
Submitted on : Sunday, October 11, 2015 - 8:46:05 PM
Last modification on : Wednesday, October 19, 2022 - 3:57:02 AM
Long-term archiving on: : Thursday, April 27, 2017 - 12:18:58 AM
File
outline.pdf
Identifiers
  • HAL Id : hal-01213440, version 1
Citation
Achim D. Brucker, Frédéric Tuong, Burkhart Wolff. Featherweight OCL: A Proposal for a Machine-Checked Formal Semantics for OCL 2.5. 15th International Workshop on OCL and Textual Modeling co-located with 18th International Conference on Model Driven Engineering Languages and Systems, Oct 2015, Karlsruhe, Germany. pp.199. ⟨hal-01213440⟩
Share
Metrics
Record views
612
Files downloads
120
