Topology and arrangement computation of semi-algebraic planar curves, Computer Aided Geometric Design, vol.25, issue.8, pp.631-651, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00343110
Topology of 2d and 3d rational curves, Computer Aided Geometric Design, vol.27, issue.7, pp.483-502, 2010. ,
A numerical-symbolic algorithm for computing the multiplicity of a component of an algebraic set, Journal of Complexity, vol.22, issue.4, pp.475-489, 2006. ,
Ein Algorithmus zum Auffinden der Basiselemente des Restklassenringes nach einem Nulldimensionalen Polynomiideal (An Algorithm for Finding the Basis Elements in the Residue Class Ring Modulo a Zero Dimensional Polynomial Ideal), Journal of Symbolic Computation, Special Issue on Logic, Mathematics, and Computer Science: Interactions, vol.41, pp.3-4, 1965. ,
Ein Algorithmisches Kriterium für die Lösbarkeit eines Algebraischen Gleichungssystems (An Algorithmic Criterion for the Solvability of Algebraic Systems of Equations), London Math. Society Lecture Note Series, vol.3, pp.535-545, 1970. ,
Computing the topology of a real algebraic plane curve whose defining equations are available only "by values, Computer Aided Geometric Design, vol.30, issue.7, pp.675-706, 2013. ,
Computing the multiplicity structure in solving polynomial systems, Proceedings of the 2005 International Symposium on Symbolic and Algebraic Computation, ISSAC '05, pp.116-123, 2005. ,
Using implicit equations of parametric curves and surfaces without computing them: Polynomial algebra by values, Computer Aided Geometric Design, vol.30, issue.1, pp.116-139, 2013. ,
Introduction à la Résolution des Systèmes Polynomiaux, vol.59, 2007. ,
Matrices in elimination theory, Journal of Symbolic Computation, vol.28, issue.1-2, pp.3-44, 1999. ,
Discriminants, Resultants, and Multidimensional Determinants, 1994. ,
Certifying isolated singular points and their multiplicity structure, Proceedings of the 2015 ACM on International Symposium on Symbolic and Algebraic Computation, ISSAC '15, pp.213-220, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01107541
Computing intersection and self-intersection loci of parametrized surfaces using regular systems and Gröbner bases, Computer Aided Geometric Design, vol.28, issue.9, pp.566-581, 2011. ,
Numerical algorithms for dual bases of positive-dimensional ideals, Journal of Algebra and Its Applications, vol.12, issue.06, p.1350018, 2013. ,
Eliminating dual spaces, 2015. ,
Higher-order deflation for polynomial systems with isolated singular solutions, Algorithms in algebraic geometry, pp.79-97, 2008. ,
Computing isolated singular solutions of polynomial systems: case of breadth one, SIAM Journal on Numerical Analysis, vol.50, issue.1, pp.354-372, 2012. ,
Computing the multiplicity structure of an isolated singular solution: Case of breadth one, Journal of Symbolic Computation, vol.47, issue.6, pp.700-710, 2012. ,
Verified error bounds for isolated singular solutions of polynomial systems, SIAM Journal on Numerical Analysis, vol.52, issue.4, pp.1623-1640, 2014. ,
Computing the nearest singular univariate polynomials with given root multiplicities, Theoretical Computer Science, vol.479, pp.150-162, 2013. ,
The Algebraic Theory of Modular Systems. Cambridge mathematical library, 1994. ,
Computation of singularities and intersections of offsets of planar curves, Computer Aided Geometric Design, vol.10, issue.5, pp.407-429, 1993. ,
Deflation and certified isolation of singular zeros of polynomial systems, Proceedings of the 36th International Symposium on Symbolic and Algebraic Computation, ISSAC '11, pp.249-256, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00556021
Singular zeros of polynomial systems, SAGA -Advances in ShApes, Geometry, and Algebra, vol.10, pp.77-103, 2014. ,
On directional multiplicities of isolated points, 2015. ,
On multiplicities in polynomial system solving, Transactions of the American Mathematical Society, vol.348, issue.8, pp.3283-3321, 1996. ,
GrÖbner duality and multiplicities in polynomial system solving, Proceedings of the 1995 International Symposium on Symbolic and Algebraic Computation, ISSAC '95, pp.167-179, 1995. ,
Isolated points, duality and residues, Journal of Pure and Applied Algebra, vol.117, pp.469-493, 1997. ,
URL : https://hal.archives-ouvertes.fr/inria-00125278
Dual Space Algorithms for Computing Multiplicity Structure of Isolated Points, 2015. ,
Using resultants for inductive Gröbner bases computation, ACM Communications in Computer Algebra, vol.45, issue.1, 2011. ,
, Numerical Polynomial Algebra. SIAM, 2004.
, , vol.1, 1991.
, , vol.2, 1991.
Computing the multiplicity structure from geometric involutive form, Proceedings of the Twenty-first International Symposium on Symbolic and Algebraic Computation, ISSAC '08, pp.325-332, 2008. ,
The closedness subspace method for computing the multiplicity structure of a polynomial system, Contemporary Mathematics, vol.496, p.347, 2009. ,
