On the use of t-coercivity to study the interior transmission eigenvalue problem, C. R. Acad. Sci, 2011. ,
The Linear Sampling Method in Inverse Electromagnetic Scattering CBMS-NSF, 2011. ,
The inverse electromagnetic scattering problem for anisotropic media, Inverse Problems, vol.26, issue.7, p.74004, 2010. ,
DOI : 10.1088/0266-5611/26/7/074004
The Existence of an Infinite Discrete Set of Transmission Eigenvalues, SIAM Journal on Mathematical Analysis, vol.42, issue.1, pp.237-255, 2010. ,
DOI : 10.1137/090769338
URL : https://hal.archives-ouvertes.fr/hal-00739145
A variational approach for the solution of the electromagnetic interior transmission problem for anisotropic media, Inverse Problems and Imaging, vol.1, pp.443-456, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00744011
Transmission eigenvalues in inverse scattering theory, Inverse Problems and Applications, Inside Out 60, 2012. ,
DOI : 10.1137/1.9781611974461
URL : https://hal.archives-ouvertes.fr/hal-00741615
Transmission eigenvalues, Inverse Problems, vol.29, issue.10, 2013. ,
DOI : 10.1088/0266-5611/29/10/100201
URL : https://hal.archives-ouvertes.fr/hal-00911761
On the interior transmission eigenvalue problem, International Journal of Computing Science and Mathematics, vol.3, issue.1/2, pp.142-167, 2010. ,
DOI : 10.1504/IJCSM.2010.033932
Inverse Acoustic and Electromagnetic Scattering Theory ,
Spectral properties of the exterior transmission eigenvalue problem, Inverse Problems, vol.30, issue.10, p.105010, 2014. ,
DOI : 10.1088/0266-5611/30/10/105010
The Electromagnetic Interior Transmission Problem for Regions with Cavities, SIAM Journal on Mathematical Analysis, vol.43, issue.4, pp.1698-1715, 2011. ,
DOI : 10.1137/100813890
Surface integral formulation of the interior transmission problem, J. Integral Equations and Applications, vol.25, pp.1123-1138, 2013. ,
The interior transmission problem for anisotropic Maxwell's equations and its applications to the inverse problem, Mathematical Methods in the Applied Sciences, vol.27, issue.18, pp.2111-2129, 2004. ,
DOI : 10.1002/mma.465
An Integral Equation for Maxwell's Equations if a Layered Medium with an Application to the Factorization Method, Journal of Integral Equations and Applications, vol.19, issue.3, pp.333-357, 2007. ,
DOI : 10.1216/jiea/1190905490
The Mathematical Theory of Time-Harmonic Maxwell's Equations, 2015. ,
DOI : 10.1007/978-3-319-11086-8
On the existence of transmission eigenvalues, Inverse Problems and Imaging, vol.3, issue.2, pp.155-172, 2009. ,
DOI : 10.3934/ipi.2009.3.155
A numerical method to compute interior transmission eigenvalues, Inverse Problems, vol.29, issue.10, p.104012, 2013. ,
DOI : 10.1088/0266-5611/29/10/104012
Ellipticity in the Interior Transmission Problem in Anisotropic Media, SIAM Journal on Mathematical Analysis, vol.44, issue.2, pp.1165-1174, 2012. ,
DOI : 10.1137/11084738X
Applications of elliptic operator theory to the isotropic interior transmission eigenvalue problem, Inverse Problems, vol.29, issue.10, p.104003, 2013. ,
DOI : 10.1088/0266-5611/29/10/104003
Strongly Elliptic Systems and Boundary Integral Equations, 2000. ,
Acoustic and electromagnetic equations Integral representations for harmonic problems, 2001. ,
Transmission Eigenvalues, SIAM Journal on Mathematical Analysis, vol.40, issue.2, pp.738-753, 2008. ,
DOI : 10.1137/070697525
Spectral analysis of the interior transmission eigenvalue problem, Inverse Problems, vol.29, issue.10, 2013. ,
DOI : 10.1088/0266-5611/29/10/104001
Discreteness of Transmission Eigenvalues via Upper Triangular Compact Operators, SIAM Journal on Mathematical Analysis, vol.44, issue.1, pp.341-354, 2012. ,
DOI : 10.1137/110836420
