On the Semantics of Object-Oriented Data Structures and Path Expressions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
UML/OCL is perceived as the de-facto standard for specifying object-oriented models in general and data models in particular. Since recently, all data types of UML/OCL comprise two different exception elements: invalid ("bottom" in semantics terminology) and null (for "non-existing element"). This has far-reaching consequences on both the logical and algebraic properties of OCL expressions as well as the path expressions over object-oriented data structures, i.e., class models. In this paper, we present a formal semantics for object-oriented data models in which all data types and, thus, all class attributes and path expressions, support invalid and null. Based on this formal semantics, we present a set of OCL test cases that can be used for evaluating the support of null and invalid in OCL tools.
Fichier non déposé
hal-01214460 , version 1 (12-10-2015)
  • HAL Id : hal-01214460 , version 1
Achim D. Brucker, Delphine Longuet, Frédéric Tuong, Burkhart Wolff. On the Semantics of Object-Oriented Data Structures and Path Expressions. Proceedings of the MODELS 2013 OCL Workshop co-located with the 16th International ACM/IEEE Conference on Model Driven Engineering Languages and Systems (MODELS 2013), Sep 2013, Miami, United States. ⟨hal-01214460⟩
114 Consultations
0 Téléchargements
