The Sequence Read Archive, Nucleic Acids Research, vol.39, issue.Database, p.1019, 2010. ,
DOI : 10.1093/nar/gkq1019
Compression of next-generation sequencing reads aided by highly efficient de novo assembly, Nucleic Acids Research, vol.40, issue.22, 2012. ,
DOI : 10.1093/nar/gks754
Efficient storage of high throughput sequencing data using reference-based compression ,
Reference-based compression of short-read sequences using path encoding, Bioinformatics, vol.31, issue.12, p.71, 2015. ,
DOI : 10.1093/bioinformatics/btv071
Compression of FASTQ and SAM Format Sequencing Data, PLoS ONE, vol.32, issue.3, 2013. ,
DOI : 10.1371/journal.pone.0059190.s001
SCALCE: boosting sequence compression algorithms using locally consistent encoding, Bioinformatics, vol.28, issue.23, pp.3051-057, 2012. ,
DOI : 10.1093/bioinformatics/bts593
Compression of DNA sequence reads in FASTQ format, Bioinformatics, vol.27, issue.6, pp.860-862, 2011. ,
DOI : 10.1093/bioinformatics/btr014
Disk-based compression of data from genome sequencing, Bioinformatics, vol.31, issue.9, p.844, 2014. ,
DOI : 10.1093/bioinformatics/btu844
BEETL-fastq: a searchable compressed archive for DNA reads, Bioinformatics, vol.30, issue.19, p.387, 2014. ,
DOI : 10.1093/bioinformatics/btu387
Data-dependent bucketing improves reference-free compression of sequencing reads, Bioinformatics, vol.31, issue.17, p.248, 2015. ,
DOI : 10.1093/bioinformatics/btv248
Large-scale compression of genomic sequence databases with the Burrows-Wheeler transform, Bioinformatics, vol.28, issue.11, pp.1415-1424, 2012. ,
DOI : 10.1093/bioinformatics/bts173
Transformations for the compression of FASTQ quality scores of next-generation sequencing data, Bioinformatics, vol.28, issue.5, pp.628-663, 2012. ,
DOI : 10.1093/bioinformatics/btr689
Lossy compression of quality scores in genomic data, Bioinformatics, vol.30, issue.15, pp.2130-136, 2014. ,
DOI : 10.1093/bioinformatics/btu183
Adaptive reference-free compression of sequence quality scores, Bioinformatics, vol.30, issue.1, p.257, 2013. ,
DOI : 10.1093/bioinformatics/btt257
Traversing the k-mer Landscape of NGS Read Datasets for Quality Score Sparsification, Research in computational molecular biology, pp.385-99, 2014. ,
DOI : 10.1007/978-3-319-05269-4_31
Less hashing, same performance: Building a better bloom filter. Algorithms-ESA, pp.2006456-67, 2006. ,
Informed and automated k-mer size selection for genome assembly, Bioinformatics, vol.30, issue.1, p.310, 2013. ,
DOI : 10.1093/bioinformatics/btt310
URL : https://hal.archives-ouvertes.fr/hal-01477511
De novo assembly and genotyping of variants using colored de Bruijn graphs, Nature Genetics, vol.44, issue.2, pp.226-258, 2012. ,
DOI : 10.1016/0198-8859(91)90078-N
Scaling metagenome sequence assembly with probabilistic de Bruijn graphs, Proceedings of the National Academy of Sciences, vol.109, issue.33, pp.13272-13279, 2012. ,
DOI : 10.1073/pnas.1121464109
Space-efficient and exact de Bruijn graph representation based on a Bloom filter, Algorithms for Molecular Biology, vol.8, issue.1, pp.22-32, 2013. ,
DOI : 10.1101/gr.131383.111
URL : https://hal.archives-ouvertes.fr/hal-00753930
Using cascading bloom filters to improve the memory usage for de brujin graphs, Algoritm Bioinforma, vol.9, pp.364-76, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00824697
Arithmetic coding for data compression, Communications of the ACM, vol.30, issue.6, pp.520-540, 1987. ,
DOI : 10.1145/214762.214771
GATB: Genome Assembly & Analysis Tool Box, Bioinformatics, vol.30, issue.20 ,
DOI : 10.1093/bioinformatics/btu406
URL : https://hal.archives-ouvertes.fr/hal-01088571
DSK: k-mer counting with very low memory usage, Bioinformatics, vol.29, issue.5, pp.652-655, 2013. ,
DOI : 10.1093/bioinformatics/btt020
URL : https://hal.archives-ouvertes.fr/hal-00778473
KMC 2: fast and resource-frugal k-mer counting, Bioinformatics, vol.31, issue.10, p.22, 2015. ,
DOI : 10.1093/bioinformatics/btv022
The Sequence Alignment/Map format and SAMtools, Bioinformatics, vol.25, issue.16, pp.2078-079, 2009. ,
DOI : 10.1093/bioinformatics/btp352
Fast and accurate short read alignment with Burrows-Wheeler transform, Bioinformatics, vol.25, issue.14, pp.1754-60, 2009. ,
DOI : 10.1093/bioinformatics/btp324
Quality score compression improves genotyping accuracy, Nature Biotechnology, vol.33, issue.3, pp.240-243, 2015. ,
DOI : 10.1038/nmeth.1923
Mapping-Free and Assembly-Free Discovery of Inversion Breakpoints from Raw NGS Reads, Algoritm Comput Biol, vol.8542, pp.119-149, 2014. ,
DOI : 10.1007/978-3-319-07953-0_10
URL : https://hal.archives-ouvertes.fr/hal-01063157
Reference-free detection of isolated SNPs, Nucleic Acids Research, vol.43, issue.2, p.11, 2015. ,
DOI : 10.1093/nar/gku1187
URL : https://hal.archives-ouvertes.fr/hal-01083715
