Leader-follower fixed-time consensus for multi–agent systems with unknown nonlinear inherent dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IET Control Theory and Applications Année : 2015
This paper focuses on the design of fixed-time consensus for first order multi-agent systems with unknown inherent nonlinear dynamics. A distributed control protocol, based on local information, is proposed to ensure the convergence of the tracking errors in finite time. Some conditions are derived to select the controller gains in order to obtain a prescribed convergence time regardless of the initial conditions. Simulations are performed to validate the theoretical results.
Automatique
LF fixed time v2.pdf (451.15 Ko) Télécharger le fichier
hal-01215015 , version 1 (13-10-2015)
Michael Defoort, Andrey Polyakov, Guillaume Demesure, Mohamed Djemai, Kalyana Chakravarthy Veluvolu. Leader-follower fixed-time consensus for multi–agent systems with unknown nonlinear inherent dynamics. IET Control Theory and Applications, 2015, 9 (14), pp.2165-2170. ⟨10.1049/iet-cta.2014.1301⟩. ⟨hal-01215015⟩
417 Consultations
1290 Téléchargements
