Conference papers
Hierarchical Zonotopal Power Ideals
Abstract : Zonotopal algebra deals with ideals and vector spaces of polynomials that are related to several combinatorial and geometric structures defined by a finite sequence of vectors. Given such a sequence $X$, an integer $k \geq -1$ and an upper set in the lattice of flats of the matroid defined by $X$, we define and study the associated $\textit{hierarchical zonotopal power ideal}$. This ideal is generated by powers of linear forms. Its Hilbert series depends only on the matroid structure of $X$. It is related to various other matroid invariants, $\textit{e. g.}$ the shelling polynomial and the characteristic polynomial. This work unifies and generalizes results by Ardila-Postnikov on power ideals and by Holtz-Ron and Holtz-Ron-Xu on (hierarchical) zonotopal algebra. We also generalize a result on zonotopal Cox modules due to Sturmfels-Xu.
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-01215037
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Tuesday, October 13, 2015 - 3:05:22 PM
Last modification on : Monday, December 28, 2020 - 10:22:04 AM
Long-term archiving on: : Thursday, April 27, 2017 - 12:00:47 AM
File
dmAO0155.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Matthias Lenz. Hierarchical Zonotopal Power Ideals. 23rd International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2011), 2011, Reykjavik, Iceland. pp.623-634, ⟨10.46298/dmtcs.2939⟩. ⟨hal-01215037⟩
Share
Metrics
Record views
39
Files downloads
467
