HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Local extrema in random permutations and the structure of longest alternating subsequences
Abstract : Let $\textbf{as}_n$ denote the length of a longest alternating subsequence in a uniformly random permutation of order $n$. Stanley studied the distribution of $\textbf{as}_n$ using algebraic methods, and showed in particular that $\mathbb{E}(\textbf{as}_n) = (4n+1)/6$ and $\textrm{Var}(\textbf{as}_n) = (32n-13)/180$. From Stanley's result it can be shown that after rescaling, $\textbf{as}_n$ converges in the limit to the Gaussian distribution. In this extended abstract we present a new approach to the study of $\textbf{as}_n$ by relating it to the sequence of local extrema of a random permutation, which is shown to form a "canonical'' longest alternating subsequence. Using this connection we reprove the abovementioned results in a more probabilistic and transparent way. We also study the distribution of the values of the local minima and maxima, and prove that in the limit the joint distribution of successive minimum-maximum pairs converges to the two-dimensional distribution whose density function is given by $f(s,t) = 3(1-s)t e^{t-s}$.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01215067
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Tuesday, October 13, 2015 - 3:06:06 PM
Last modification on : Wednesday, August 7, 2019 - 12:19:20 PM
Long-term archiving on: : Wednesday, April 26, 2017 - 11:52:00 PM
File
dmAO0172.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Dan Romik. Local extrema in random permutations and the structure of longest alternating subsequences. 23rd International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2011), 2011, Reykjavik, Iceland. pp.825-834, ⟨10.46298/dmtcs.2956⟩. ⟨hal-01215067⟩
Share
Metrics
Record views
48
Files downloads
571
