New interface
Conference papers
The Shi arrangement and the Ish arrangement
Abstract : This paper is about two arrangements of hyperplanes. The first — the Shi arrangement — was introduced by Jian-Yi Shi to describe the Kazhdan-Lusztig cells in the affine Weyl group of type A. The second — the Ish arrangement — was recently defined by the first author who used the two arrangements together to give a new interpretation of the q,t-Catalan numbers of Garsia and Haiman. In the present paper we will define a mysterious "combinatorial symmetry'' between the two arrangements and show that this symmetry preserves a great deal of information. For example, the Shi and Ish arrangements share the same characteristic polynomial, the same numbers of regions, bounded regions, dominant regions, regions with c "ceilings'' and d "degrees of freedom'', etc. Moreover, all of these results hold in the greater generality of "deleted'' Shi and Ish arrangements corresponding to an arbitrary subgraph of the complete graph. Our proofs are based on nice combinatorial labellings of Shi and Ish regions and a new set partition-valued statistic on these regions.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01215091
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Tuesday, October 13, 2015 - 3:06:36 PM
Last modification on : Wednesday, June 26, 2019 - 2:48:03 PM
Long-term archiving on: : Thursday, April 27, 2017 - 12:14:47 AM
File
dmAO0106.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Drew Armstrong, Brendon Rhoades. The Shi arrangement and the Ish arrangement. 23rd International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2011), 2011, Reykjavik, Iceland. pp.51-62, ⟨10.46298/dmtcs.2890⟩. ⟨hal-01215091⟩
Share
Metrics
Record views
58
Files downloads
611
