Pop-stacks in parallel, Information Processing Letters, vol.70, issue.2, pp.63-67, 1999. ,
DOI : 10.1016/S0020-0190(99)00049-6
<mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn mathvariant="bold">2</mml:mn><mml:mo>+</mml:mo><mml:mn mathvariant="bold">2</mml:mn><mml:mo stretchy="false">)</mml:mo></mml:math>-free posets, ascent sequences and pattern avoiding permutations, Journal of Combinatorial Theory, Series A, vol.117, issue.7, pp.884-909, 2010. ,
DOI : 10.1016/j.jcta.2009.12.007
Probì emes combinatoires de commutation et réarrangements, Lecture Notes in Mathematics, issue.85, 1969. ,
A direct encoding of Stoimenow's matchings as ascent sequences, Australasian Journal of Combinatorics, vol.49, pp.47-59, 2011. ,
Partition and composition matrices, Journal of Combinatorial Theory, Series A, vol.118, issue.5, pp.1624-1637, 2011. ,
DOI : 10.1016/j.jcta.2011.02.001
URL : https://hal.archives-ouvertes.fr/hal-01215096
Ascent sequences and upper triangular matrices containing nonnegative integers, Electronic Journal of Combinatorics, vol.17, issue.116pp, p.53, 2010. ,
Enumerating $(\bf{2+2})$-free posets by indistinguishable elements, Journal of Combinatorics, vol.2, issue.1, 2011. ,
DOI : 10.4310/JOC.2011.v2.n1.a6
A conjectured combinatorial formula for the Hilbert series for diagonal harmonics, Discrete Mathematics, vol.298, issue.1-3, pp.189-204, 2005. ,
DOI : 10.1016/j.disc.2004.01.022
The On-Line Encyclopedia of Integer Sequences, 2009. ,
DOI : 10.1007/978-3-540-73086-6_12
Vassiliev invariants and a strange identity related to the Dedekind eta-function, Topology, vol.40, issue.5, pp.945-960, 2001. ,
DOI : 10.1016/S0040-9383(00)00005-7
