Circuit and bond polytopes on series–parallel graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Optimization Année : 2015
In this paper, we describe the circuit polytope on series–parallel graphs. We first show the existence of a compact extended formulation. Though not being explicit, its construction process helps us to inductively provide the description in the original space. As a consequence, using the link between bonds and circuits in planar graphs, we also describe the bond polytope on series–parallel graphs.
CircuitsAndBondsInSP.pdf (161.29 Ko) Télécharger le fichier
hal-01215899 , version 1 (05-12-2017)
Sylvie Borne, Pierre Fouilhoux, Roland Grappe, Mathieu Lacroix, Pierre Pesneau. Circuit and bond polytopes on series–parallel graphs. Discrete Optimization, 2015, 17, pp.55-68. ⟨10.1016/j.disopt.2015.04.001⟩. ⟨hal-01215899⟩
267 Consultations
155 Téléchargements
