ON THE MINIMUM WEIGHT CODEWORDS OF SOME BINARY BCH CODES
We give the true minimum distances of some BCH codes of length 255 and 511, which were not known. We describe the set of the minimum weight codewords of the BCH codes with designed distance 2^{m-2}-1
