Combining Appearance and Structure from Motion Features for Road Scene Understanding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Paul Sturgess
  • Fonction : Auteur
  • PersonId : 971751
Karteek Alahari
In this paper we present a framework for pixel-wise object segmentation of road scenes that combines motion and appearance features. It is designed to handle street-level imagery such as that on Google Street View and Microsoft Bing Maps. We formulate the problem in a CRF framework in order to probabilistically model the label likelihoods and the a priori knowledge. An extended set of appearance-based features is used, which consists of textons, colour, location and HOG descriptors. A novel boosting approach is then applied to combine the motion and appearance-based features. We also incorporate higher order potentials in our CRF model, which produce segmentations with precise object boundaries. We evaluate our method both quantitatively and qualitatively on the challenging Cambridge-driving Labeled Video dataset. Our approach shows an overall recognition accuracy of 84% compared to the state-of-the-art accuracy of 69%.
sturgess09.pdf (411.03 Ko) Télécharger le fichier
hal-01216879 , version 1 (17-10-2015)
Paul Sturgess, Karteek Alahari, Lubor Ladicky, Philip H. S. Torr. Combining Appearance and Structure from Motion Features for Road Scene Understanding. BMVC - British Machine Vision Conference, Sep 2009, London, United Kingdom. ⟨10.5244/C.26.127⟩. ⟨hal-01216879⟩
669 Consultations
729 Téléchargements
