New interface
Conference papers
The Stretchable Arms for Collaborative Remote Guiding
Abstract : Figure 1: The stretchable guiding arms, controlled by the remote expert's location, from the agent's viewpoint. On the left, the arms are extended and red because the guide is ahead of the agent. On the right, the agent has reached the guide's location and the guiding arms retrieve their initial length and green color. Abstract The help of a remote expert to guide an agent in performing a physical task can be advantageous in many ways: saving time and money by avoiding travel, and thus increasing the rate of intervention. In many situations, the remote expert wishes to guide the agent by first placing him in the correct location to achieve the task. However, as the agent is not a robot, the expert can not use a location controller to place the agent. Instead, interaction techniques must enable the expert to achieve this task before physical manipulation guidance. In this paper, we propose a novel interaction technique for remote guiding based on arm gestures. First, the remote expert (using a VR setup) virtually collocates himself with the agent (using an AR setup), then controls virtual arms collocated with both users' shoulders. Second, if the expert starts to move forward to grasp a virtual object, the virtual arms start to stretch in order to keep the shoulders' collocation on the agent's side. This metaphor allows the agent to understand the direction of the expert's motion easily while preserving the naturalness of the interaction and avoiding the use of a frustum to represent the expert's head location. Categories and Subject Descriptors (according to ACM CCS): Information Interfaces and Presentation (e.g. HCI) [H.5.2]: User Interfaces—Computer Graphics [I.3.6]: Methodology and Techniques— †
Document type :
Conference papers
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-01218184
Contributor : Valérie Gouranton Connect in order to contact the contributor
Submitted on : Tuesday, October 20, 2015 - 5:11:26 PM
Last modification on : Monday, March 14, 2022 - 11:08:13 AM
Long-term archiving on: : Friday, April 28, 2017 - 5:43:38 AM
File
ICAT-gogo-draft-HAL.pdf
Identifiers
Citation
Morgan Le Chénéchal, Thierry Duval, Valérie Gouranton, Jérôme Royan, Bruno Arnaldi. The Stretchable Arms for Collaborative Remote Guiding. Proceedings of International Conference on Artificial Reality and Telexistence Eurographics Symposium on Virtual Environments, 2015, Kyoto, Japan. ⟨10.2312/egve.20151322⟩. ⟨hal-01218184⟩
Share
Metrics
Record views
635
Files downloads
229
