On the complexity of equal shortest path routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks Année : 2015
In telecommunication networks packets are carried from a source s to a destination t on a path determined by the underlying routing protocol. Most routing protocols belong to the class of shortest path routing protocols. In such protocols, the network operator assigns a length to each link. A packet going from s to t follows a shortest path according to these lengths. For better protection and efficiency, one wishes to use multiple (shortest) paths between two nodes. Therefore the routing protocol must determine how the traffic from s to t is distributed among the shortest paths. In the protocol called OSPF-ECMP (for Open Shortest Path First-Equal Cost Multiple Path) the traffic incoming at every node is uniformly balanced on all outgoing links that are on shortest paths. In that context, the operator task is to determine the " best " link lengths, toward a goal such as maximizing the network throughput for given link capacities. In this work, we show that the problem of maximizing even a single commodity flow for the OSPF-ECMP protocol cannot be approximated within any constant factor ratio. Besides this main theorem, we derive some positive results which include polynomial-time approximations and an exponential-time exact algorithm.
ospf-journal.pdf (358.7 Ko) Télécharger le fichier
hal-01218473 , version 1 (21-10-2015)
Frédéric Giroire, Stéphane Pérennes, Issam Tahiri. On the complexity of equal shortest path routing. Networks, 2015, ⟨10.1002/net.21612⟩. ⟨hal-01218473⟩
144 Consultations
310 Téléchargements
