Vector Lyapunov Function based Stability for a Class of Impulsive Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper contributes to the exponential stability analysis for impulsive dynamical systems based on a vector Lyapunov function and its divergence operator. The method relies on a 2D time domain representation. The results are applied to analyze the exponential stability of linear impulsive systems based on LMIs. Some examples illustrate the feasibility of the proposed approach.
CDC15_0059_FI_Hector_VLF.pdf (277.22 Ko) Télécharger le fichier
hal-01218955 , version 1 (21-10-2015)
  • HAL Id : hal-01218955 , version 1
Héctor Ríos, Laurentiu Hetel, Denis Efimov. Vector Lyapunov Function based Stability for a Class of Impulsive Systems. 54th IEEE Conference on Decision and Control (CDC), 2015, Dec 2015, Osaka, Japan. ⟨hal-01218955⟩
564 Consultations
382 Téléchargements
