On the Representation and Estimation of Spatial Uncertainty, The International Journal of Robotics Research, vol.5, issue.4, 1986. ,
DOI : 10.1177/027836498600500404
Robust method for outdoor localization of a mobile robot using received signal strength in low power wireless networks, 2008 IEEE International Conference on Robotics and Automation, 2008. ,
DOI : 10.1109/ROBOT.2008.4543183
An efficient least-squares trilateration algorithm for mobile robot localization, 2009 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2009. ,
DOI : 10.1109/IROS.2009.5354370
Mapping Partially Observable Features from Multiple Uncertain Vantage Points, The International Journal of Robotics Research, vol.16, issue.6, 2002. ,
DOI : 10.1177/0278364902021010889
Robust range-only beacon localization, IEEE Journal of Oceanic Engineering, 2006. ,
A pure probabilistic approach to range-only SLAM, 2008 IEEE International Conference on Robotics and Automation, 2008. ,
DOI : 10.1109/ROBOT.2008.4543404
A general Gaussian-mixture approach for range-only mapping using multiple hypotheses, 2010 IEEE International Conference on Robotics and Automation, 2010. ,
DOI : 10.1109/ROBOT.2010.5509704
Undelayed 3d roslam based on gaussian-mixture and reduced spherical parametrization, IEEE/RSJ Int. Conf. on Intelligent Robots and Systems (IROS), 2013. ,
A Robust Method of Localization and Mapping Using Only Range, Experimental Robotics, 2009. ,
DOI : 10.1007/978-3-642-00196-3_40
Efficient robot-sensor network distributed SEIF range-only SLAM, 2014 IEEE International Conference on Robotics and Automation (ICRA), 2014. ,
DOI : 10.1109/ICRA.2014.6907023
Range-only slam with interpolated range data, 2006. ,
A comparison of SLAM algorithms with range only sensors, 2014 IEEE International Conference on Robotics and Automation (ICRA), 2014. ,
DOI : 10.1109/ICRA.2014.6907532
Efficient, generalized indoor WiFi GraphSLAM, 2011 IEEE International Conference on Robotics and Automation, 2011. ,
DOI : 10.1109/ICRA.2011.5979643
A spectral learning approach to rangeonly slam, Int. Conf. on Machine Learning (ICML), 2013. ,
Sensor-based globally exponentially stable range-only simultaneous localization and mapping, Robotics and Autonomous Systems, vol.68, 2015. ,
DOI : 10.1016/j.robot.2015.01.010
Robocentric map joining: Improving the consistency of EKF-SLAM, Robotics and Autonomous Systems, vol.55, issue.1, 2007. ,
DOI : 10.1016/j.robot.2006.06.005
Single range aided navigation and source localization: Observability and filter design, Systems & Control Letters, vol.60, issue.8, 2011. ,
DOI : 10.1016/j.sysconle.2011.05.004
Navigating with ranging radios: Five data sets with ground truth, Journal of Field Robotics, vol.35, issue.9, 2009. ,
DOI : 10.1002/rob.20311
Welcome to ROS Topics [ROS Topics, IEEE Robotics & Automation Magazine, vol.17, issue.1, 2010. ,
DOI : 10.1109/MRA.2010.935808
Range-only SLAM for robots operating cooperatively with sensor networks, Proceedings 2006 IEEE International Conference on Robotics and Automation, 2006. ICRA 2006., 2006. ,
DOI : 10.1109/ROBOT.2006.1642011
