Comparison of mapping algorithms used in high-throughput sequencing: application to Ion Torrent data, BMC Genomics, vol.15, issue.1, p.264, 2014. ,
DOI : 10.1186/1471-2164-13-341
URL : https://hal.archives-ouvertes.fr/inserm-00975719
Systematic evaluation of spliced alignment programs for RNA-seq data, Nature Methods, vol.27, issue.12, pp.1185-1191, 2013. ,
DOI : 10.1186/1471-2164-12-45
A mostly traditional approach improves alignment of bisulfite-converted DNA, Nucleic Acids Research, vol.40, issue.13, p.100, 2012. ,
DOI : 10.1093/nar/gks275
Mason?a read simulator for second generation sequencing data, 2010. ,
A novel and well-defined benchmarking method for second generation read mapping, BMC Bioinformatics, vol.12, issue.1, p.210, 2011. ,
DOI : 10.1186/1471-2105-9-11
ART: a next-generation sequencing read simulator, Bioinformatics, vol.28, issue.4, pp.593-594, 2011. ,
DOI : 10.1093/bioinformatics/btr708
pIRS: Profile-based Illumina pair-end reads simulator, Bioinformatics, vol.28, issue.11, pp.1533-1535, 2012. ,
DOI : 10.1093/bioinformatics/bts187
Snakemake--a scalable bioinformatics workflow engine, Bioinformatics, vol.28, issue.19, pp.2520-2522, 2012. ,
DOI : 10.1093/bioinformatics/bts480
The Sequence Alignment/Map format and SAMtools, Bioinformatics, vol.25, issue.16, pp.2078-2079, 2009. ,
DOI : 10.1093/bioinformatics/btp352
Aligning sequence reads, clone sequences and assembly contigs with BWA-MEM. arXiv:1303, pp.3997-3999, 2013. ,
GemSIM: general, error-model based simulator of next-generation sequencing data, BMC Genomics, vol.13, issue.1, p.74, 2012. ,
DOI : 10.1093/nar/gkn425
PBSIM: PacBio reads simulator--toward accurate genome assembly, Bioinformatics, vol.29, issue.1, pp.119-121, 2013. ,
DOI : 10.1093/bioinformatics/bts649
SInC: an accurate and fast error-model based simulator for SNPs, Indels and CNVs coupled with a read generator for short-read sequence data, BMC Bioinformatics, vol.15, issue.1, p.40, 2014. ,
DOI : 10.1016/j.bbrc.2005.06.040
XS: a FASTQ read simulator FASTQSim: platform-independent data characterization and in silico read generation for NGS datasets, BMC Research Notes BMC Res. Notes, vol.7, issue.7, p.533, 2014. ,
