The Study on the Outline Model of the Agriculture Product Price Information Service, Agriculture Network Information, issue.02, 2004. ,
Changing Focus on Interoperability in Information Systems:From System, Syntax, Structure to Semantics, 1999. ,
DOI : 10.1007/978-1-4615-5189-8_2
An intelligent approach to information integration [C]. Formal Ontology in Information Systems, 1998. ,
Information systems interoperability, ACM Transactions on Information Systems, vol.22, issue.4, pp.595-632, 2004. ,
DOI : 10.1145/1028099.1028103
Research on Semantic Heterogeneity Elimination for information integration, 2009. ,
Research of semantic heterogeneity in information integration, Application Research of Computers, issue.08, pp.2349-2351, 2008. ,
Information Integration Using Contextual Knowledge and Ontology Merging [D]. Cambridge: Massachusetts Institute of Technology, 2003. ,
Context Interchange as a Scalable Solution to Interoperating Amongst Heterogeneous Dynamic Services, Proc of the 3rdWorkshop on eBusiness. Washington DC: [s.n.], pp.150-161, 2004. ,
Learning object identification rules for information integration, Special Issue on Data Extraction, Cleaning, and Reconciliation, p.26, 2001. ,
DOI : 10.1016/S0306-4379(01)00042-4
Learning domain-independent string transformation weights for high accuracy object identification, Proceedings of the eighth ACM SIGKDD international conference on Knowledge discovery and data mining , KDD '02, pp.350-359, 2002. ,
DOI : 10.1145/775047.775099
Research on Context Mediation Based Semantic Information Integration Method, 2009. ,
Abnormal data detection in agriculture search engine, 2010. ,
Complex Adaptive Agriculture Vertical Search Model and its Implementation, 2010. ,
Semantic Research and Implementation on Agricultural Vertical Search Engine, p.2012 ,
