The Effects of Urea Fertilisation and Genotype on Yield, Nitrogen Use Efficiency, 15 N and 13 C in Wheat, Annals of Applied Biology, issue.2, pp.153-243, 2008. ,
An approach to the genetics of nitrogen use efficiency in maize, Journal of Experimental Botany, vol.55, issue.396, pp.55-295, 2004. ,
DOI : 10.1093/jxb/erh006
Root Induced Changes in Potential Nitrification and Nitrate Reductase Activity of the Rhizospheric Soil of Wheat (triticum aestivum L) and Chichpea (cicer arietinum L.) [J], Pakistan Journal of Botany, issue.4, pp.38-991, 2006. ,
Grafting to Improve Nitrogen-use Efficiency Traits in Tobacco Plants, Journal of the Science of Food and Agriculture, issue.6, pp.86-1014, 2006. ,
Interaction of Sulfur and Nitrogen Nutrition in Tobacco (Nicotiana tabacum) Plants: Significance of Nitrogen Source and Root Nitrate Reductase, Plant Biology, vol.66, issue.5, pp.638-646, 2007. ,
DOI : 10.1093/aob/mci254
Transformation Law of Different Formal Nitrogen Fertilizer in Paddy Field and its Effect on Growth and Nicotine Content of Flue-cured Tobacco, pp.30-34, 2009. ,
Correlation Between Corn Leaf Spectral Reflectance and Leaf Total Nitrogen and Chlorophyll Content under Different Nitrogen Level, Scientia Agricultura Sinica, issue.11, pp.38-2268, 2005. ,
Monitoring Canopy Leaf Pigment Density in Wheat with Hyperspectral Remote Sensing, Acta Ecologica Sinica, issue.10, pp.28-4902, 2008. ,
Monitoring of Cotton Canopy Chlorophyll Density and Leaf Nitrogen Accumulation Status by Using Hyperspectral Data, Acta Agronomica Sinica, issue.6, pp.33-931, 2007. ,
Usefulness of spectral reflectance indices as durum wheat yield predictors under contrasting Mediterranean conditions, International Journal of Remote Sensing, vol.31, issue.22, pp.24-4403, 2003. ,
DOI : 10.1111/j.1365-3180.1974.tb01084.x
Correlation Between Agronomic Parameters and Spectral Vegetation Index in Winter Wheat Under Different Nitrogen Levels, Agricultural Research in the Arid Areas, pp.16-22, 2005. ,
Spectral Characteristics of Corn Under Different Nitrogen Treatments, Spectroscopy and Spectral Analysis, issue.3, pp.30-715, 2010. ,
Diagnosis of Nitrogen Statues in Rice Leaves with the Canopy Spectral Reflectance, J]. Sci Agric Sinica, issue.7, pp.36-807, 2003. ,
Determination of accurate extinction coefficients and simultaneous equations for assaying chlorophylls a and b extracted with four different solvents: verification of the concentration of chlorophyll standards by atomic absorption spectroscopy, Biochimica et Biophysica Acta (BBA) - Bioenergetics, vol.975, issue.3, pp.384-394, 1989. ,
DOI : 10.1016/S0005-2728(89)80347-0
Relationship Between Hyperspectra Parameters and Physiological and Biochemical Indexes of Flue-cured Tobacco Leaves, Scientia Agricultura Sinica, issue.5, pp.40987-994, 2007. ,
Study on Correlation Between Chlorophyll Density of Winter Wheat and Hyperspectral Data Agricultural Research in the Arid Areas, pp.2574-79, 2007. ,
Hyperspectral Data and Their Relationships Correlative to the Pigment Contents for Rice Under Different Nitrogen Support Level, Journal of Remote Sensing, vol.8, issue.2, pp.185-192, 2004. ,
