Abstract : In order to solve the deliquesced fertilizer adheres to fertilizer
conveying pipe, and leads to fertilizer conveying pipe blocked, a kind
of fertilizer amount adjusting mechanism of deep-fertilization machinery
for paddy field was designed. This adjusting mechanism was taken as
research object, the distance between hinge axis and the center of blade
connection seat, the distance between hinge axis and sliding limited
post axis, the rotation angular velocity of cam ring and the angular
velocity of blade rotating around hinge axis were taken as objective
function, the diameter of fertilizer through-hole, the number of blades
and the changing range of curvature radius of guide chute were taken as
constraint conditions, the aided design and analysis software for
fertilizer amount adjusting mechanism was programmed by VB software,
through which kinematics optimization was carried out for fertilizer
amount adjusting mechanism. The obtained optimal parameter ranges are:
the radius of inner ring of cam is 30mm, the number of blade is 6, the
distance between the hinge axis and the center of blade connection seat
is 47.5mm, the distance between hinge axis and sliding limited post axis
is 12.5mm, the rotation angular velocity of cam ring is 25-35r/min, the
angular velocity of blade rotating around hinge axis is 30-35r/min.
According to optimization results, the fertilizer amount adjusting
mechanism was simulated by Pro/E software, the simulation results were
validated by experiment. The results show that the adjustable range of
diameter of fertilizer through-hole for fertilizer amount adjusting
mechanism is 9-56mm, the sliding limited post of blade and the guiding
chute of cam ring have good sliding performance, and the designed
fertilizer amount adjusting mechanism can satisfy the expected design
requirements.
https://hal.inria.fr/hal-01220905 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 27, 2015 - 9:58:39 AM Last modification on : Wednesday, January 17, 2018 - 10:44:15 AM Long-term archiving on: : Thursday, January 28, 2016 - 10:32:38 AM
