Non-destructive measurement of acidity, soluble solids and firmness of Satsuma mandarin using Vis/NIR-spectroscopy techniques, Journal of Food Engineering, vol.77, issue.2, pp.313-319, 2006. ,
DOI : 10.1016/j.jfoodeng.2005.06.036
Nondestructive measurement of internal quality of Nanfeng mandarin fruit by charge coupled device near infrared spectroscopy, Agriculture, vol.71, pp.10-14, 2010. ,
Determination of soluble solids and firmness of apples by Vis/NIR transmittance, Journal of Food Engineering, vol.93, issue.4, pp.416-420, 2009. ,
Prediction of the optimum harvest time of ???Scarlet??? apples using DR-UV???Vis and NIR spectroscopy, Postharvest Biology and Technology, vol.69, pp.15-23, 2012. ,
DOI : 10.1016/j.postharvbio.2012.02.009
Effect of fruit moving speed on predicting soluble solids content of 'Cuiguan' pears (Pomaceae pyrifolia Nakai cv. Cuiguan) using PLS and LS-SVM regression, Postharvest Biology and Technology, issue.1, pp.51-86, 2009. ,
Variable selection in visible and near-infrared spectra: Application to on-line determination of sugar content in pears, Journal of Food Engineering, vol.109, issue.1, pp.142-147, 2012. ,
Comparing density and VNIR methods for predicting quality parameters of yellow-fleshed kiwifruit (Actinidia chinensis), Postharvest Biology and Technology, vol.46, issue.1, pp.46-47, 2007. ,
DOI : 10.1016/j.postharvbio.2007.04.003
Vis/NIR spectroscopy and chemometrics for the prediction of soluble solids content and acidity (pH) of kiwifruit, Biosystems Engineering, vol.106, issue.3, pp.106-295, 2010. ,
DOI : 10.1016/j.biosystemseng.2010.04.002
Prediction of total soluble solid content in intact and cut melons and watermelons using near infrared spectroscopy, Journal of Near Infrared Spectroscopy, vol.16, issue.1, pp.16-91, 2008. ,
DOI : 10.1255/jnirs.771
Measurement of soluble solids content in melon by transmittance spectroscopy, Sensor Letters, vol.2012, issue.1012, pp.570-573 ,
Nondestructive measurement of internal quality in pear using genetic algorithms and FT-NIR spectroscopy, Journal of Food Engineering, vol.84, pp.206-213, 2008. ,
Application of successive projections algorithm for variable selection to determine organic acids of plum vinegar, pp.1430-1436, 2009. ,
Visible/near infrared-partial least-squares analysis of Brix in sugar cane juice, Chemometrics and Intelligent Laboratory Systems, vol.102, issue.2, pp.100-109, 2010. ,
DOI : 10.1016/j.chemolab.2010.04.009
Uninformative variable elimination for improvement of successive projections algorithm on spectral multivariable selection with different calibration algorithms for the rapid and non-destructive determination of protein content in dried laver, Analytical Methods, vol.3, pp.1790-1796, 2011. ,
Internal quality determination of fruit with bumpy surface using visible and near infrared spectroscopy and chemometrics: A case study with mulberry fruit, Biosystems Engineering, vol.109, pp.377-384, 2011. ,
Determination of Soluble Solids Content in Navel Oranges by Vis/NIR Semi-transmission Spectra Combined with CARS Method, Spectroscopy and Spectral Analysis, issue.12, pp.32-3229, 2012. ,
Application of successive projections algorithm in optimising near infrared spectroscopic calibration model, Journal of Instrumental Analysis, vol.26, issue.1, pp.66-69, 2007. ,
Use of FT-NIR spectrometry in noninvasive measurements of soluble solid contents (SSC) of " Fuji " apple based on different PLS models, pp.43-51, 2007. ,
Genetic algorithm-based wavelength selection method for spectral calibration, Journal of Chemometrics, vol.40, issue.3, pp.10-19, 2011. ,
DOI : 10.1002/cem.1339
Elimination of Uninformative Variables for Multivariate Calibration, Analytical Chemistry, vol.68, issue.21, pp.68-3851, 1996. ,
DOI : 10.1021/ac960321m
Application of genetic algorithm-PLS for feature selection in spectral data sets, Journal of Chemometrics, vol.40, issue.5-6, pp.643-655, 2000. ,
DOI : 10.1002/1099-128X(200009/12)14:5/6<643::AID-CEM621>3.0.CO;2-E
Genetic algorithms applied to feature selection in PLS regression: how and when to use them, Chemometrics and Intelligent Laboratory Systems, vol.41, issue.2, pp.195-207, 1998. ,
DOI : 10.1016/S0169-7439(98)00051-3
The successive projections algorithm for variable selection in spectroscopic multicomponent analysis, Chemometrics and Intelligent Laboratory Systems, vol.57, issue.2, pp.57-65, 2001. ,
DOI : 10.1016/S0169-7439(01)00119-8
A variable elimination method to improve the parsimony of MLR models using the successive projections algorithm, Chemometrics and Intelligent Laboratory Systems, vol.92, issue.1, pp.92-83, 2008. ,
DOI : 10.1016/j.chemolab.2007.12.004
Key wavelengths screening using competitive adaptive reweighted sampling method for multivariate calibration, Analytica Chimica Acta, vol.648, issue.1, pp.77-84, 2009. ,
Visible/near-infrared spectra for linear and nonlinear calibrations: a case to predict soluble solids contents and pH value in peach, Bioprocess Technology, issue.48, pp.1376-1383, 2011. ,
Comparison of commercial near infrared transmittance and reflectance instruments for analysis of whole grains and seeds, Journal of Near Infrared Spectroscopy, vol.1, issue.1, pp.25-32, 1993. ,
DOI : 10.1255/jnirs.3
