HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Measurement and Study on Drying Shrinkage Characteristic of Tobacco Lamina Based on Computer Vision
Abstract : Accurate evaluation of shrinkage characteristic for tobacco lamina during drying process is important for optimizing tobacco primary process. The present work developed a detection and characterization method of shrinkage characteristic based on computer vision. Effect of types and dimensions of tobacco lamina on the shrinkage characteristic were investigated and shrinkage rate variation at different drying stages was also analyzed by this method. The results show that percentage reduction of area, which is obtained by detecting tobacco lamina area before and after drying, can be used to reflect the shrinkage characteristic of tobacco lamina. RSD of measurement results by this method is less than 6% under test conditions. Compared with upper tobacco leaf, middle tobacco leaf shows the higher shrinkage rate of 14.3%. Dimensions of tobacco lamina also have significant effect on its shrinkage characteristic. The larger size (up 30mm mesh) tobacco lamina shows a higher shrinkage rate. Shrinkage rate of tobacco lamina is closely related to moisture content variation during drying. The shrinkage of tobacco lamina during drying mainly occurs within the moisture content range of 20% to 14%.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01220933
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, October 27, 2015 - 10:13:21 AM
Last modification on : Wednesday, January 17, 2018 - 10:43:34 AM
Long-term archiving on: : Thursday, January 28, 2016 - 10:36:20 AM
File
978-3-642-54344-9_37_Chapter.p...
Identifiers
Citation
Wenkui Zhu, Zhaogai Wang, Delong Xu, Jinsong Du. Measurement and Study on Drying Shrinkage Characteristic of Tobacco Lamina Based on Computer Vision. 7th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2013, Beijing, China. pp.306-314, ⟨10.1007/978-3-642-54344-9_37⟩. ⟨hal-01220933⟩
Share
Metrics
Record views
88
Files downloads
111
