Abstract : In this system, the electromagnetic proportional valve is the
actuator, and the valve controlled motor is controlled object, and the
speed sensor is the feedback element, to send out the orders by
industrial computer, to control the motor output speed by controller.
According to the principle of the circuit and fluid mechanics, set up
the mathematical model of the valve controlled hydraulic motor variable
fertilization system. PID parameters tuning of system were performed by
Ziegler-Nichols method, get the coefficient of increment algorithm. The
step response of P, PI and PID of variable rate fertilization the system
were studied by MATLAB/ SIMULINK, results show that: PID algorithm
system, the overshoot was small, setting time was short, the number for
oscillations was little compared with the P algorithm and PI algorithm,
the dynamic performance of the system is excellent. The laboratory
experiments results showed that: In the process of system operation, PID
algorithm tracking speed was rapid, and steady-state error is smaller.
Therefore, the electro-hydraulic proportional variable fertilization
system with PID algorithm has good dynamic performance and steady state
performance, and can meet the requirements of variable
assignment.
https://hal.inria.fr/hal-01220934 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 27, 2015 - 10:13:41 AM Last modification on : Wednesday, January 17, 2018 - 10:43:34 AM Long-term archiving on: : Thursday, January 28, 2016 - 10:36:30 AM
Liang Chunying, Wang Xi, Ji Jianwei, Xu Qianhui, Lü Peng. Research of PID Algorithm for Valve Controlled Hydraulic Motor Variable Rate Fertilizer Control System. 7th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2013, Beijing, China. pp.315-326, ⟨10.1007/978-3-642-54344-9_38⟩. ⟨hal-01220934⟩
