Construct and Study Mathematical Model of Direct-acting Proportional Control Valve Hydraulic Pressure Motor, J].. Machine Building Automation, issue.3, pp.38-141, 2009. ,
Development and performance of electrohydraulic proportion control system of variable rate fertilizer[J]. Transactions of the CSAE, pp.218-222 ,
Meng Zhijun, Design and experiment of variable rate fertilizer applicator. Transactions of the CSAE, pp.114-117, 2004. ,
Research about Variable Rate Fertilization Closed-loop Control System of Electro-hydraulic Speed, Chinese Agricultural Science Bulletin, issue.07, pp.25-272, 2009. ,
Design and experiment on PLC control system of variable rate fertilizer, Transactions of the Chinese Society of Agricultural Machinery, pp.38-84, 2007. ,
Variable rate fertilizer control system based on CAN bus[J]. Transactions of the CSAE, pp.24127-132, 2008. ,
Design of Variable Rate Fertilization Controller Based on CAN Bus, Transactions of the Chinese Society of Agricultural Machinery, pp.39101-105, 2008. ,
Development and performance of electrohydraulic proportion control system of variable rate fertilizer, Transactions of the CSAE, vol.26, issue.2, pp.218-222, 2010. ,
LiuHui, Development and performance assessment ofmapbased variable rate granule application system, Journal of JIANGSU UNIVERSITY, vol.30, issue.4, pp.338-342, 2009. ,
PID Control Strategy of the Variable Rate, Transactions of the Chinese Society of Agricultural Machinery Fertilization Control System, pp.41-157, 2010. ,
Niu Xiaoying, et a.l Design and experiment on PLC control system of variable rate fertilizer, Transactions of the Chinese Society for Agricultural Machinery, pp.38-84, 2007. ,
FIS-based method to generate bivariate control parameters regulation sequence forfertilization, Transactions of the CSAE, issue.11, pp.27-134, 2011. ,
Bivariate Fertilization Control Sequence Optimization Based on Relevance Vector Machine, Transactions of the Chinese Society of Agricultural Machinery, pp.2011-2053 ,
Optimization Parameters of PID Controller Parameters Based on Genetic Algorithm, Computer simulation, vol.11, pp.180-183, 2010. ,
Research on variable rate seeding and fertilization technology, Journal of Northeast Agricultural University, vol.40, issue.3, pp.115-120, 2009. ,
Iterative learning control of electrol-hydraulic proportional feeding system in slotting machine for metalbar cropping, International Journal of Machine Tools&Manufacture, issue.7, pp.45923-931, 2005. ,
Iterative learning control on electrohydraulic position servo systems of the pump-controlled cylinder [J], Journal of Taiyuan University of Science and Technology, vol.27, issue.4, pp.277-280, 2006. ,
Study on the efficiency of differential cylinder system driven with servo motor and constant pump, Proceedings of the CSEE, pp.2693-98, 2006. ,
Research on control system of variable rate fertilizer applicator in precision agriculture based on NDVI, Journal of Agricultural University of Hebei, issue.2, pp.94-98, 200528. ,
Compensation for secondary uncertainty in electro-hydraulic servo system by gain adaptive sliding mode variable structure control, Journal of Central South University of Technology, vol.22, issue.4, pp.256-263, 2008. ,
DOI : 10.1007/s11771-008-0048-1
Theoretic analysis and experiment of valveless electro-hydraulic servo system, China Mechanical Engineering, issue.21, pp.141822-1823, 2003. ,
Zero phase error real time control for flight simulator servo system, Chinese Journal of Mechanical Engineering (English Edition), vol.17, issue.01, pp.132-135, 2004. ,
DOI : 10.3901/CJME.2004.01.132
The research and application prospect of precise fertilization techniques, pp.76-79, 200612. ,
Variable-rate, digitally controlled metering device Applied engineering in agriculture, pp.39-44, 2000. ,
Evaluation of Application Accuracy and Performance of a Hydraulically Operated Variable-Rate Aerial Appli-cation System[J]. Transactions of the ASABE, pp.52715-722, 2009. ,
