Abstract : The temperature of crop leaf is closely related to leaf respiration,
transpiration and its drought resistance. The rapid measurement of crop
temperature is of great significance for breeding and agricultural
cultivation management. The traditional infrared thermometer can only
obtain the single point temperature. In this study, a high sensitive
thermal infrared imager was used for recording the leaf temperature
distribution of maize seedling stage. The temperature distribution of 5
different drought resistance varieties of maize in both normal water and
drought stress treatment were analyzed. It turned out that there were
obvious differences in temperature for different leaf position. The
average temperature in the middle part of the leaf is 0.94℃ higher
than the leaf apex and 0.81℃ higher than the leaf base. The
results also showed that the leaf temperature is higher than that of the
stem. And the average temperature of the whole blade is 24.07℃,
which is higher than the background soil temperature (19.53℃). For
the same maize variety, the leaf temperature of drought stress treatment
is higher than that of normal water treatment. It was also found that
the temperature of maize with good drought resistance is higher than
that of the bad one, furthermore, the better the higher. The results
above showed that the characteristics of temperature distribution in
crops could be effectively obtained by using thermal infrared images,
which also provided potential for the rapid identification of crop
drought resistance.
https://hal.inria.fr/hal-01220940 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 27, 2015 - 10:15:52 AM Last modification on : Wednesday, January 17, 2018 - 10:44:15 AM Long-term archiving on: : Thursday, January 28, 2016 - 10:38:14 AM
