Effects on Traits of Corn Hybrids under Drought at the Different Growing Stages, Yongning: Journal of maize Science, vol.12, pp.23-26, 2004. ,
The engineering technique for agricultural drought and their application, Beijng: Engineering Sciences, vol.2012, issue.139, pp.85-88 ,
Bonnet et al. New glyphosate screening technique by infrared thermometry, Australia: Fourth International Symposium on Adjuvants for Agrochemicals, pp.297-302, 1995. ,
Imaging techniques in early detection of plants stress ,
Combining thermal and visible imagery for estimating canopy temperature and identifying plant stress, Journal of Experimental Botany, vol.55, issue.401, pp.55-1423, 2004. ,
DOI : 10.1093/jxb/erh146
Use of thermography for quantitative studies of spatial and temporal variation of stomatal conductance over leaf surfaces, Plant, Cell and Environment, vol.113, issue.9, pp.1043-1055, 1999. ,
DOI : 10.1016/0168-1923(94)05082-H
Determination of stomatal conductance by means of infrared thermography, Infrared Physics & Technology, vol.46, issue.5, pp.429-439, 2005. ,
DOI : 10.1016/j.infrared.2004.09.001
Identification of Maize Drought-Tolerance at Seedling Stage Based on Leaf Temperature Using Infrared Thermography, Beijing: Scientia Agricultura Sinica, pp.422192-2201, 2009. ,
Canopy-air Temperature Difference of Rice in Key Water Requirement Periods, Journal of Irrigation and Drainage, vol.30, issue.4, pp.80-82, 2011. ,
Thermal infrared imaging of crop canopies for the remote diagnosis and quantification of plant responses to water stress in the field, Functional Plant Biology, vol.36, issue.11, pp.987-989, 2009. ,
DOI : 10.1071/FP09123
A new screening method for osmotic component of salinity tolerance in cereals using infrared thermography, Functional Plant Biology, vol.36, pp.970-977, 2009. ,
An infrared-based coefficient to screen plant environmental stress: concept, test and applications [J], Functional Plant Biology, vol.36, pp.990-997, 2009. ,
Canopy temperature on clear and cloudy days can be used to estimate varietal differences in stomatal conductance in rice, 2009. ,
Discuss on Evaluating Method to Drought-resistance of Maize in Seedling Stage, Journal of maize Science, vol.12, issue.2, pp.73-75, 2004. ,
Harm by drought and mechanism of drought resistance of plant ,
Drought Resistance of Different Maize Varieties in Germination Stage, Guizhou: Guizhou Agricultural Sciences, 2005. ,
Identification of peanut drought-tolerance at seedling stage using infrared thermography[J]. Qingdao: Chinese journal of oil crop sciences, pp.33632-636, 2011. ,
Application of Infrared Thermography in the Research of Plant Mechanism Response to Drought, Beijing: Chinese Agriculture Science Bulletin, vol.2012, issue.03, pp.2817-2839 ,
The Study of Stomatal Conductance Estimation of Populus deltoids Bartr.x Populus ussuriensis Kom, By Infrared Thermography [J]. Beijing: Chinese Agriculture Science Bulletin, issue.31, pp.2865-70, 2012. ,
Application of Near Infrared Reflectance Spectroscopy in Determination of Drought Resistance of Winter Wheat, Hengshui: Journal of Hebei Agriculture Science, 2011. ,
