Comparison between the largescale environments of moderate and intense precipitating systems in the Mediterranean region - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monthly Weather Review Année : 2009
A characterization of the large-scale environment associated with precipitating systems in the Mediterranean region, based mainly on NOAA-16 Advanced Microwave Sounding Unit (AMSU) observations from 2001 to 2007, is presented. Channels 5, 7, and 8 of AMSU-A are used to identify upper-level features, while a simple and tractable method, based on combinations of channels 3–5 of AMSU-B and insensitive to land–sea contrast, was used to identify precipitation. Rain occurrence is widespread over the Mediterranean in wintertime while reduced or short lived in the eastern part of the basin in summer. The location of convective precipitation shifts from mostly over land from April to August, to mostly over the sea from September to December. A composite analysis depicting large-scale conditions, for cases of either rain alone or extensive areas of deep convection, is performed for selected locations where the occurrence of intense rainfall was found to be important. In both cases, an upper-level trough is seen to the west of the target area, but for extreme rainfall the trough is narrower and has larger amplitude in all seasons. In general, these troughs are also deeper for extreme rainfall. Based on the European Centre for Medium-Range Weather Forecasts operational analyses, it was found that sea surface temperature anomalies composites for extreme rainfall are often about 1 K warmer, compared to nonconvective precipitation conditions, in the vicinity of the affected area, and the wind speed at 850 hPa is also stronger and usually coming from the sea.
Funatsu2009.pdf (1.11 Mo) Télécharger le fichier
hal-01221074 , version 1 (03-08-2021)
Paternité
Beatriz M. Funatsu, Chantal Claud, Jean-Pierre Chaboureau. Comparison between the largescale environments of moderate and intense precipitating systems in the Mediterranean region. Monthly Weather Review, 2009, 137 (11), pp.3933-3959. ⟨10.1175/2009MWR2922.1⟩. ⟨hal-01221074⟩
257 Consultations
50 Téléchargements
