Energy efficient content distribution, Communications (ICC), 2013 IEEE International Conference on, pp.4233-4238, 2013. ,
DOI : 10.1109/icc.2013.6655228
URL : https://hal.archives-ouvertes.fr/hal-00743248
Energy consumption in IP networks, 34th European Conference on, p.1, 2008. ,
On the edge forwarding index problem for small graphs, Networks, vol.37, issue.38, pp.249-255, 1993. ,
DOI : 10.1002/net.3230230406
Energy-aware umts core network design, The 11th International Symposium on Wireless Personal Multimedia Communications, 2008. ,
The forwarding index of communication networks, IEEE Transactions on Information Theory, vol.33, issue.2, pp.224-232, 1987. ,
DOI : 10.1109/TIT.1987.1057290
Minimizing Routing Energy Consumption: From Theoretical to Practical Results, 2010 IEEE/ACM Int'l Conference on Green Computing and Communications & Int'l Conference on Cyber, Physical and Social Computing, 2010. ,
DOI : 10.1109/GreenCom-CPSCom.2010.147
URL : https://hal.archives-ouvertes.fr/hal-00531468
Grid spanners with low forwarding index for energy efficient networks, International Network Optimization Conference (INOC), 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01095179
Graphs with optimal forwarding indices: What is the best throughput you can get with a given number of edges? Research Report RR-8752, 2015. ,
On forwarding indices of networks, Discrete Applied Mathematics, vol.23, issue.2, pp.103-123, 1989. ,
DOI : 10.1016/0166-218X(89)90022-X
The forwarding indices of graphs - a survey, Opuscula Mathematica, vol.33, issue.2, 2012. ,
DOI : 10.7494/OpMath.2013.33.2.345
Multicommodity max-flow min-cut theorems and their use in designing approximation algorithms, Journal of the ACM, vol.46, issue.6, pp.787-832, 1999. ,
DOI : 10.1145/331524.331526
The geometry of graphs and some of its algorithmic applications, Combinatorica, vol.15, pp.577-591, 1994. ,
The forwarding index of directed networks, Discrete Applied Mathematics, vol.68, issue.3, pp.279-291, 1996. ,
DOI : 10.1016/0166-218X(95)00072-Y
Small cubic graphsscience_engineering/csem/ research/programs/flinders-hamiltonian-cycle-project/graph-database.cfm, flinders Univ projet 16. MILLER, Mirka amd ?IRÁN, J.: Moore graphs and beyond: A survey of the degree/diameter problem, Electronic Journal of Combinatorics, vol.61, pp.1-63, 2005. ,
Moore graphs and beyond: A survey of the degree/diameter problem, dynamic Survey DS14, 2013. ,
Some applications of Laplace eigenvalues of graphs, Graph Symmetry, NATO ASI Series, pp.225-275, 1997. ,
DOI : 10.1007/978-94-015-8937-6_6
SNDlib 1.0-Survivable Network Design Library, Networks, vol.3, issue.3, pp.276-286, 2010. ,
DOI : 10.1002/net.20371
The maximum concurrent flow problem, Journal of the ACM, vol.37, issue.2, pp.318-334, 1990. ,
DOI : 10.1145/77600.77620
Improved Bounds for Mixing Rates of Markov Chains and Multicommodity Flow, Combinatorics, Probability and Computing, vol.11, issue.04, pp.351-370, 1992. ,
DOI : 10.1016/0095-8956(89)90029-4
Expanding and forwarding, Discrete Applied Mathematics, vol.58, issue.1, pp.67-78, 1995. ,
DOI : 10.1016/0166-218X(93)E0118-I
Stability properties of constrained queueing systems and scheduling policies for maximum throughput in multihop radio networks, IEEE Transactions on Automatic Control, vol.37, issue.12, pp.1936-1948, 1992. ,
DOI : 10.1109/9.182479
The forwarding index of communication networks with given connectivity, Discrete Applied Mathematics, vol.37, issue.38, pp.37-38, 1992. ,
DOI : 10.1016/0166-218X(92)90129-X
The Forwarding Indices of Random Graphs, Random Structures & Algorithms, vol.23, issue.1, pp.107-116, 1992. ,
DOI : 10.1002/rsa.3240030108
The forwarding indices of graphs - a survey, Opuscula Mathematica, vol.33, issue.2, 1204. ,
