Modeling Spontaneous Metastasis following Surgery: An In Vivo-In Silico Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cancer Research Année : 2016
Rapid improvements in the detection and tracking of early-stage tumor progression aim to guide decisions regarding cancer treatments as well as predict metastatic recurrence in patients following surgery. Mathematical models may have the potential to further assist in estimating metastatic risk, particularly when paired with in vivo tumor data that faithfully represent all stages of disease progression. Herein we describe mathematical analysis that uses data from mouse models of spontaneous metastasis developing after surgical removal of orthotopically implanted primary tumors. Both presurgical (primary tumor) and postsurgical (metastatic) growth was quantified using bioluminescence and was then used to generate a mathematical formalism based on general laws of the disease (i.e. dissemination and growth). The model was able to fit and predict pre-/post-surgical data at the level of the individual as well as the population. Our approach also enabled retrospective analysis of clinical data describing the probability of metastatic relapse as a function of primary tumor size. In these data-based models, inter-individual variability was quantified by a key parameter of intrinsic metastatic potential. Critically, our analysis identified a highly nonlinear relationship between primary tumor size and postsurgical survival, suggesting possible threshold limits for the utility of tumor size as a predictor of metastatic recurrence. These findings represent a novel use of clinically relevant models to assess the impact of surgery on metastatic potential and may guide optimal timing of treatments in neoadjuvant (presurgical) and adjuvant (postsurgical) settings to maximize patient benefit.
Cancer
benzekryEbos_surgery_all_HAL.pdf (4.75 Mo) Télécharger le fichier
hal-01222046 , version 1 (30-10-2015)
hal-01222046 , version 2 (30-10-2015)
Paternité - Pas d'utilisation commerciale
Sébastien Benzekry, Amanda Tracz, Michalis Mastri, R. Corbelli, Dominique Barbolosi, et al.. Modeling Spontaneous Metastasis following Surgery: An In Vivo-In Silico Approach. Cancer Research, 2016, 76 (3), pp.535 - 547. ⟨10.1158/0008-5472.CAN-15-1389⟩. ⟨hal-01222046v2⟩
681 Consultations
492 Téléchargements
