An Augmented Lagrangian Approach to the Constrained Optimization Formulation of Imaging Inverse Problems, IEEE Transactions on Image Processing, vol.20, issue.3, pp.681-695, 2011. ,
DOI : 10.1109/TIP.2010.2076294
Approximate classification via earthmover metrics, SODA, 2004. ,
On approximating arbitrary metrices by tree metrics, Proceedings of the thirtieth annual ACM symposium on Theory of computing , STOC '98, 1998. ,
DOI : 10.1145/276698.276725
An experimental comparison of min-cut/max-flow algorithms for energy minimization in vision, 2004. ,
Fast approximate energy minimization via graph cuts, pp.1222-1239, 2001. ,
DOI : 10.1109/iccv.1999.791245
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6806
A variable window approach to early vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.12, pp.1283-1294, 1998. ,
DOI : 10.1109/34.735802
Hyperconvexity and tight-span theory for diversities, Advances in Mathematics, 2012. ,
DOI : 10.1016/j.aim.2012.08.008
Approximation algorithms for the metric labeling problem via a new linear programming formulation, 12 th Annual ACM-SIAM Symposium on Discrete Algorithms, pp.109-118, 2001. ,
Mean shift: a robust approach toward feature space analysis, PAMI, 2002. ,
DOI : 10.1109/34.1000236
Minimizing Energies with Hierarchical Costs, International Journal of Computer Vision, vol.18, issue.9, 2012. ,
DOI : 10.1007/s11263-012-0531-x
Fast Approximate Energy Minimization with Label Costs, CVPR, 2010. ,
DOI : 10.1007/s11263-011-0437-z
Parsimonious labeing, ICCV, 2015. ,
A tight bound on approximating arbitrary metrics by tree metrics, Proceedings of the thirty-fifth ACM symposium on Theory of computing , STOC '03, 2003. ,
DOI : 10.1145/780542.780608
Efficient belief propagation for early vision, Proceedings of the 2004 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2004. CVPR 2004., 2004. ,
DOI : 10.1109/CVPR.2004.1315041
The Representation and Matching of Pictorial Structures, IEEE Transactions on Computers, vol.22, issue.1, pp.67-92, 1973. ,
DOI : 10.1109/T-C.1973.223602
A graph cut algorithm for high-order Markov random fields, ICCV, 2011. ,
Transforming an arbitrary minsum problem into a binary one, 2006. ,
Stochastic relaxation, gibbs distributions, and the bayesian restoration of images, IEEE Trans. Pattern Anal. Mach. Intell, vol.6, issue.6, pp.721-741, 1984. ,
Fixing max-product: Convergent message passing algorithms for MAP LP-relaxations, pp.553-560, 2007. ,
A constant factor approximation algorithm for a class of classification problems, Proceedings of the thirty-second annual ACM symposium on Theory of computing , STOC '00, 2000. ,
DOI : 10.1145/335305.335397
Norm-Product Belief Propagation: Primal-Dual Message-Passing for Approximate Inference, IEEE Transactions on Information Theory, vol.56, issue.12, pp.6294-6316, 2010. ,
DOI : 10.1109/TIT.2010.2079014
Exact optimization for markov random fields with convex priors, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.10, pp.1333-1336, 2003. ,
DOI : 10.1109/TPAMI.2003.1233908
Reflection methods for user-friendly submodular optimization, pp.1313-1321, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00905258
Fast and smooth: Accelerated dual decomposition for MAP inference, pp.503-510, 2010. ,
Generalized roof duality, Discrete Applied Mathematics, vol.160, issue.16-17, pp.16-172419, 2012. ,
DOI : 10.1016/j.dam.2012.06.009
URL : http://dx.doi.org/10.1016/j.dam.2012.06.009
Approximation algorithms for classification problems with pairwise relationships: Metric labeling and Markov random fields, STOC, 1999. ,
Convergent Tree-Reweighted Message Passing for Energy Minimization, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.28, issue.10, pp.1568-1583, 2006. ,
DOI : 10.1109/TPAMI.2006.200
Generalized roof duality and bisubmodular functions, Discrete Applied Mathematics, vol.160, issue.4-5, pp.1144-1152, 2010. ,
DOI : 10.1016/j.dam.2011.10.026
URL : http://arxiv.org/abs/1005.2305
Minimizing a sum of submodular functions, Discrete Applied Mathematics, 2012. ,
DOI : 10.1016/j.dam.2012.05.025
What energy functions can be minimized via graph cuts?, pp.147-159, 2004. ,
Beyond Loose LP-Relaxations: Optimizing MRFs by Repairing Cycles, pp.806-820, 2008. ,
DOI : 10.1007/978-3-540-88690-7_60
URL : https://hal.archives-ouvertes.fr/hal-00918715
Beyond pairwise energies: Efficient optimization for higher-order MRFs, 2009 IEEE Conference on Computer Vision and Pattern Recognition, pp.2985-2992, 2009. ,
DOI : 10.1109/CVPR.2009.5206846
MRF Energy Minimization and Beyond via Dual Decomposition, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.3, pp.531-552, 2011. ,
DOI : 10.1109/TPAMI.2010.108
URL : https://hal.archives-ouvertes.fr/hal-00856311
Approximate Labeling via Graph Cuts Based on Linear Programming, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.8, pp.1436-1453, 2007. ,
DOI : 10.1109/TPAMI.2007.1061
Performance vs computational efficiency for optimizing single and dynamic MRFs: Setting the state of the art with primal-dual strategies, Computer Vision and Image Understanding, vol.112, issue.1, pp.14-29, 2008. ,
DOI : 10.1016/j.cviu.2008.06.007
URL : https://hal.archives-ouvertes.fr/hal-00918699
Rounding-based moves for metric labeling, NIPS, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01069910
MAP estimation of semi-metric MRFs via hierarchical graph cuts, UAI, 2009. ,
An analysis of convex relaxations for MAP estimation, NIPS, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00773608
Improved moves for truncated convex models, NIPS, 2008. ,
Inference methods for CRFs with co-occurence statistics, 2013. ,
Ergodic, primal convergence in dual subgradient schemes for convex programming, Mathematical Programming, pp.283-312, 1999. ,
DOI : 10.1007/s101070050090
Sdp gaps and ugc hardness for multiway cut, 0-extension, and metric labeling, Proceedings of the fourtieth annual ACM symposium on Theory of computing, STOC 08, 2008. ,
DOI : 10.1145/1374376.1374379
Loopy belief propagation for approximate inference: An empirical study, UAI, pp.467-476, 1999. ,
Incremental Subgradient Methods for Nondifferentiable Optimization, SIAM Journal on Optimization, vol.12, issue.1, pp.109-138, 2001. ,
DOI : 10.1137/S1052623499362111
Approximate Primal Solutions and Rate Analysis for Dual Subgradient Methods, SIAM Journal on Optimization, vol.19, issue.4, pp.1757-1780, 2009. ,
DOI : 10.1137/070708111
Submodular decomposition framework for inference in associative Markov networks with global constraints, CVPR 2011, pp.1889-1896, 2011. ,
DOI : 10.1109/CVPR.2011.5995361
Combinatorial Optimization: Algorithms and Complexity, Englewoods Cliffs, N.J, 1982. ,
Probabilistic Reasoning in Intelligent Systems: Networks of Plausible Inference, 1988. ,
Some generalized order-disorder transformations, Cambridge Philosophical Society, 1952. ,
DOI : 10.1103/PhysRev.60.252
A study of Nesterov's scheme for Lagrangian decomposition and MAP labeling, CVPR 2011, pp.1817-1823, 2011. ,
DOI : 10.1109/CVPR.2011.5995652
Efficient MRF energy minimization via adaptive diminishing smoothing, pp.746-755 ,
Syntactic analysis of two-dimensional visual signals in noisy conditions, Kibernetika, 1976. ,
Polynomial-time exact inference in NP-hard binary MRFs via reweighted perfect matching, 13-th International Conference on Artificial Intelligence and Statistics (AISTATS), pp.717-724, 2010. ,
Recovery of primal solutions when using subgradient optimization methods to solve Lagrangian duals of linear programs, Operations Research Letters, vol.19, issue.3, pp.105-113, 1996. ,
DOI : 10.1016/0167-6377(96)00019-3
Minimization methods for nondifferentiable functions, 1985. ,
Tightening LP relaxations for MAP using message passing, pp.656-664, 2008. ,
Approximation Algorithms, 2001. ,
DOI : 10.1007/978-3-662-04565-7
Efficient graph-based energy minimization methods in computer vision, 1999. ,
Graph Cut Based Optimization for MRFs with Truncated Convex Priors, 2007 IEEE Conference on Computer Vision and Pattern Recognition, 2007. ,
DOI : 10.1109/CVPR.2007.383249
MAP Estimation Via Agreement on Trees: Message-Passing and Linear Programming, IEEE Transactions on Information Theory, vol.51, issue.11, pp.3697-3717, 2005. ,
DOI : 10.1109/TIT.2005.856938
Markov Random Field modeling, inference & learning in computer vision & image understanding: A survey, Computer Vision and Image Understanding, vol.117, issue.11, pp.1610-1627, 2013. ,
DOI : 10.1016/j.cviu.2013.07.004
URL : https://hal.archives-ouvertes.fr/hal-00858390
On the optimality of solutions of the max-product belief-propagation algorithm in arbitrary graphs, IEEE Transactions on Information Theory, vol.47, issue.2, pp.723-735, 2001. ,
DOI : 10.1109/18.910585
A Linear Programming Approach to Max-Sum Problem: A Review, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.7, pp.1165-1179, 2007. ,
DOI : 10.1109/TPAMI.2007.1036
Linear programming relaxations and belief propagation ? an empirical study, pp.1887-1907, 2006. ,
Tightening MRF relaxations with planar subproblems, pp.770-777, 2011. ,
23 3.6.2 P n Potts model, p.35 ,
